About to take the plunge... Livestreaming!
Re: About to take the plunge... Livestreaming!
RGBlink Mini has just been ordered...
For what I need, multiview preview is essential... entry-level ATEM doesn't have that.
As it will often not be me pressing the buttons, simplicity of operation and lack of oo-er controls is highly desirable. RGBlink has that.
The built in multiview screen is a big plus for on the road... tiny I know, but does save taking a monitor for times when a mini-rig is of the essence.
Once it arrives I shall do some audio experimenting and report back...
Watch this space...
Watch this space...
- Mike Stranks
Jedi Poster - Posts: 10467 Joined: Fri Jan 03, 2003 12:00 am
The RGB link looks like a nice compact piece of kit. Multiview is essential even if it is really tiny.
I thought I would share a couple of live-streams we did in the fall.
This is from an artist Lucette. There is an opening act Amy Nelson and Lucette is about an hour in. For the astute audio fan, the big blue van in the background is the Rolling Stones Mobile.
https://amplify.nmc.ca/video/watch-rbc- ... y-lucette/
The other video is a great classical group, Land’s End playing in a blues bar for a Sunday brunch. Fun to shoot a classical ensemble.
https://amplify.nmc.ca/video/watch-stin ... -ensemble/
This was all done at the National Music Centre in Calgary.
Enjoy.
Enjoy.
Watched a few excerpts from the video and, to the untrained eye, it looks pretty good. Interestingly I've just spent this afternoon transferring some 2" tapes that were recorded by Mick McKenna with the Rolling Stones Mobile.
Posts: 14379 Joined: Mon Sep 10, 2001 12:00 am
Quick update....
The RGBlink Mini arrived yesterday and I gave it a workout this afternoon with two cameras and an iPad.
The built-in preview screen is good to make sure you've got a good link, but I think it would simply be too small for field work... we shall see. Today I hooked-up to a 24" TV with the HDMI output on the Mini set to 'Preview'. That was good...
So first impressions are of a versatile little unit which will do what I want... now to order some more HDMI cables...
Oh! I should add that I did my first one-camera plus mic livestream the other day. Surprisingly easy and uncomplicated through my YouTube channel. It was just a 'private' stream for proof of concept...
- Mike Stranks
Sounds good Mike. I think we’ve chatted on this topic on t’other thread?
My one bit of advice when it comes to live-streaming, is to test, test again and when you’ve got it right, have a sleep and then test again. You get the point!
When you’ve got a setup that’s been through the above, don’t change a single thing. I’ve been caught out once or twice trying to make, what I thought were little changes, to be tripped up.
I use a variety of either audio fed back into the camera OR a frame or two or delay on my ATEM switcher. Seems to work. Mixing and matching between wireless & wired audio sources is a bit of a headache but easily solvable if not mixed together, which is often the case in my situ (eg. Wireless lavs ‘v’ a stereo pair on an organ or choir). I’ve recently purchased a zoom f6 because I’m tired of either lumping around an x32 rack or being limited to a stereo pair of xlr inputs on my camera (if a single cam is sufficient but 3 or more mics needed). An F8n or Sound Devices unit probably would’ve been my first choice but budget limited and Hugh’s review reassured me. Plus as a solo shooter (streamer?!) the concept of worrying less about incorrect gain settings means I can be confident of fixing in post. Although I realise the ‘live’ mix needs to be decent. Shame about the unbalanced 3.5mm output but otherwise it wins on features at the price. I’ve just bought a small cheeseplate which lifts the unit sufficiently to clear the chunky manfrotto head I have. So my single cam setup has just had a major upgrade. I now need to test, test, test!
One other thing I’ve heard about but not yet explored...
Using an audio embedder. That way the audio is sent out from the X32 via AES, into an embedder via SPDIF, and into the ATEM as HDMI, without any need for D/A & A/D conversion. Not sure if this is worth the effort but sounds interesting.
Glad to hear that the RGBlink Mini seems to be working for you. When you connected to the external monitor and set it to Preview, do you get the multiview display on the external monitor?
Most of my experience has been with the Blackmagic ATEM switchers, which have worked well, but they are pricier.
Humf wrote: ↑Mon Aug 02, 2021 10:55 pm Sounds good Mike. I think we’ve chatted on this topic on t’other thread?
As NASA say: test as you fly, fly as you test.
Mattsong wrote: ↑Tue Aug 03, 2021 4:44 am Glad to hear that the RGBlink Mini seems to be working for you. When you connected to the external monitor and set it to Preview, do you get the multiview display on the external monitor?
I'm still exploring and experimenting...
I should also have said that another reason for choosing the RGBlink was that it can be set up and operated without any recourse to a computer at all - ie all through internal menus.
Regarding outputs... both the HDMI out and the USB 3 out can be set to show 'Preview' or 'Post'. So I'm intending to use a smallish external monitor connected to the HDMI out for previewing and the USB output set to 'Post' for streaming.
The preview output divides the screen vertically into two. Top half is a 'Preview' and 'Post' (On Air) display; bottom half shows the preview of the 4 inputs. 'Post' also has switchable indication of combined audio levels.
Audio can be the usual config of external (via the audio input on the Mini) follow the video source or lock to one video input... I haven't explored that in any detail yet.
The unit is fanless, but has a chunky heatsink on the base. Gets quite warm during operation...
- Mike Stranks
Hi Mike,
does the Mini allow you to set an audio delay or would you need to set that elsewhere before routing it in?
Drew
Drew
Forum Aficionado -
Posts: 24658 Joined: Sun Jul 05, 2015 12:00 am
Hi Drew
I've just checked and the unit itself doesn't allow that facility... I don't know about the software as I've not yet downloaded it.
I was at first going to use some form of external delay and then route the audio into the Mini... I could still do this if I use my Zoom F4 as an intermediate device.
However, my discussions with those who do far more sophisticated livestreams and have far better kit than I do has led me to the conclusion to route the audio into a camera and then lock the audio to that HDMI input via the Mini. Advice is that that will be the simplest and most effective route.
- Mike Stranks
Hmmm. Makes sense.
Thanks Mike.
Thanks Mike.
Forum Aficionado -
Returning to this after a few months...
I've used the RGBlink Mini several times in Zoom calls and it's worked flawlessly.
I tried a test YouTube livestream yesterday and couldn't get YouTube to recognise it as a webcam - even though all other software was seeing it fine. I thought this might be because I was using an elderly and lo-spec laptop so did a mega Win10 update (several hours) and tried again. Same result: Zoom YouTube (Win reports drivers are fine)
So tried it on my desktop behemoth PC. Same again...
I've now put in a support email request to RGBlink...
- Mike Stranks
Thanks for the update.
- ManFromGlass
Longtime Poster - Posts: 6691 Joined: Sun Jul 24, 2011 12:00 am Location: O Canada
Hope you get it sorted Mike.
Live streaming is a whole new world. (sometimes of pain!) We installed a Black Magic ATEM Mini pro, a couple of DataVideo PTZ 140s and a DataVideo RMC180 PTZ controller to enable us to live-stream our Church services
It all works pretty well, and the ATEM is configured with our Youtube stream credentials so it's one button go-live
I've set up a mix layer on our A&H SQ5 for a dedicated stream mix which goes to the ATEM and tweaked the sound sync settings in the ATEM.
Our biggest challenge is the volunteer PA team have now become a volunteer PA AND Broadcast team, responsible for camera switching, video overlays and PIP from the laptop, FOH mix and stream mix. It can get a bit full on at times! But we don't profess to deliver a broadcast quality production, like some of the big mega-churches, but we are able to offer something to the many people who still feel nervous about attending in person in this covid time.
We have a number of care homes in the area using Amazon fire-sticks on their communal TVs able to tune in every Sunday.
Pending a reply from RGBlink (who asked me a few questions and have now gone very quiet) I have continued experimenting and tweaking.
I've been able to livestream successfully using the RGBlink Mini as a single source into OBS and then out thru YouTube. It proved the concept, as the RGBxxx did exactly what it was supposed to with three HDMI sources connected. However, the video was extremely jerky and freezing all the time on both the stream and the OBS recording. I'll give it another go in a while, dropping the sampling rate somewhat. I'm somewhat surprised as it's a reasonably powerful PC... and it handles the RGB thru Zoom with nary a glitch...
As Mark One says, this live-streaming aspect needs lots of working through...
Mark: A friend in a church in Oxford that does live-streaming now has a minimum of three people for each stream: one for sound, one on the ATEM and one handling production/cueing people etc.
- Mike Stranks
