Buying microphone cable, 100m drums.
Re: Buying microphone cable, 100m drums.
Hugh Robjohns wrote: Mon Jul 26, 2021 10:39 pm Starquad's famed superior interference rejection only applies to interference sources lying physically alongside the cable. So it's beneficial if you're running mic cables directly alongside lighting dimmer power cables, for example, but there's no advantage at all in more typical applications.
Moreover, the much higher capacitance compared to standard cables can become problematic on longer cable runs.
If you're concerned about RF interference then it would be better to invest in Neutrik's EMC XLR connectors and use a good quality cable, ideally with a double-Reussen screen.
The only interference I’m worried about is my partner shouting outside the piano room "are you recording?"
Posts: 8847 Joined: Sat Jul 12, 2003 12:00 am
That would be an ecumenical matter.
Arpangel wrote: Tue Jul 27, 2021 7:40 am
Heh! Can you not rig a red "Silence Recording" lamp outside the room? And whatever cables you finally get matey, I would chuck in at least one Cat5e/6 shielded cable as well...SO handy for all sorts of signals. If you find a local network installer he will probably GIVE you 30mtrs 'end of a box'.
Posts: 13114 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Post by blinddrew »
I have often wondered if there were midi-triggered "recording" lights available. I know that if I had one that I had to remember to switch on it would be a waste of time; but something that came on automatically... :thumbup:
Posts: 16148 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by SimonZ »
There are !!!
'Punchlight' have a few options and there are others 👍
SimonZ
Posts: 289 Joined: Fri Jun 15, 2007 12:00 am Location: Portsmouth UK
SimonZ wrote: Tue Jul 27, 2021 9:49 am There are !!!
And we have a thread describing the Elf's adventures with an Arduino from a few weeks ago building something similar.
Posts: 11246 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by blinddrew »
James Perrett wrote: Tue Jul 27, 2021 10:21 am
The Elf's creation (like his mixes) is well beyond me, but I shall check out 'Punchlight'. :thumbup:
Post by Luke W »
blinddrew wrote: Tue Jul 27, 2021 9:44 am I have often wondered if there were midi-triggered "recording" lights available. I know that if I had one that I had to remember to switch on it would be a waste of time; but something that came on automatically... :thumbup:
We have quite the opposite problem at work with people forgetting to turn them off, it's left me standing around like a lemon a few times now. :lol:
Luke W
Posts: 1067 Joined: Thu Feb 19, 2009 1:00 am Location: Northamptonshire, UK
Studio - Techical Services - Bespoke Construction
Post by blinddrew »
Well, given the prices of the Punchlight ones I might be thinking again about making my own. If I can make it switch off automatically as well I'll let you know. ;)
If you've got 100m drums, you're going to need some bloody long drumsticks! :D
Posts: 11989 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Post by Mike Stranks »
Most mixers specifically designed for broadcast have microswitches in the fader tracks. This meant that when I was in BBC Local Radio, faders could:
* Switch on the Red Light when a mic channel was opened
* Mute any loudspeaker in the room when a mic channel was opened
* Auto-start a CD player (f'r instance) when the relevant channel was opened
... and of course being BBC faders they opened by being pulled towards you! :)
Mike Stranks
Posts: 8555 Joined: Fri Jan 03, 2003 1:00 am
In addition, on big network broadcasting consoles, the same microswitches could also be configured to auto-cancel the channel's PFL mode, and unmute any pre-fade audience PA foldback sends.
Sadly, the days of faders opening towards the operator are long gone.
Posts: 31998 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Wonks wrote: Tue Jul 27, 2021 4:38 pm If you've got 100m drums, you're going to need some bloody long drumsticks! :D
And a gargantuan Persian rug! ;)
Posts: 3786 Joined: Mon Jul 21, 2003 11:00 pm Location: A studio deep in the fenlands of Cambridgeshire, UK
Search 15,424 SOS Reviews+Techniques articles: www.soundonsound.com/search
PreSonus Studio One Professional, Apple Logic Pro X, PreSonus Studio 192 audio interface, Apple M1 MacBook Pro 13", Mac Pro trashcan, iPad Pro (1st gen), PreSonus Sceptre 8 monitors, KRK RokIt monitors, PreSonus Faderport 1, 8 and 16 mix controllers, Avid Eleven Rack, various Lexicon/Roland reverb hardware, Brian May Burns red special, Gibson Les Paul, Fender 'fat' Strat, Guild S100, Takamine 6-string electric-acoustic.
Hugh Robjohns wrote: Tue Jul 27, 2021 6:04 pm Sadly, the days of faders opening towards the operator are long gone.
Just turn the mixer around 180° - instant nostalgia! :tongue:
Posts: 6495 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Some of my works | The SOS Forum Album projects
Post by RichardT »
And an elephant to hear the fundamental.
RichardT
Posts: 1228 Joined: Fri Aug 13, 2004 12:00 am Location: London UK
Post by Dan LB »
Hugh, why do you say ‘sadly’? Do find reverse faders more intuitive or preferable in some way?
The option is there on a couple of Calrec Alphas that we have but I’ve never tried it. I must give it a shot sometime!
Dan LB
Posts: 1611 Joined: Sat Jan 28, 2006 1:00 am Location: Wicklow, Ireland
