Buying microphone cable, 100m drums.
Re: Buying microphone cable, 100m drums.
James Perrett wrote: Tue Jul 27, 2021 10:21 am
SimonZ wrote: Tue Jul 27, 2021 9:49 am There are !!!
'Punchlight' have a few options and there are others 👍
And we have a thread describing the Elf's adventures with an Arduino from a few weeks ago building something similar.
The Elf's creation (like his mixes) is well beyond me, but I shall check out 'Punchlight'. :thumbup:
Posts: 24646 Joined: Sun Jul 05, 2015 12:00 am Location: York
Ignore the post count, I still have no idea what I'm doing...
Post by Luke W »
blinddrew wrote: Tue Jul 27, 2021 9:44 am I have often wondered if there were midi-triggered "recording" lights available. I know that if I had one that I had to remember to switch on it would be a waste of time; but something that came on automatically... :thumbup:
We have quite the opposite problem at work with people forgetting to turn them off, it's left me standing around like a lemon a few times now. :lol:
Luke W
Posts: 1542 Joined: Thu Feb 19, 2009 12:00 am Location: Northamptonshire, UK
Well, given the prices of the Punchlight ones I might be thinking again about making my own. If I can make it switch off automatically as well I'll let you know. ;)
If you've got 100m drums, you're going to need some bloody long drumsticks! :D
Posts: 17020 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Post by Mike Stranks »
Most mixers specifically designed for broadcast have microswitches in the fader tracks. This meant that when I was in BBC Local Radio, faders could:
* Switch on the Red Light when a mic channel was opened
* Mute any loudspeaker in the room when a mic channel was opened
* Auto-start a CD player (f'r instance) when the relevant channel was opened
... and of course being BBC faders they opened by being pulled towards you! :)
Mike Stranks
Posts: 10467 Joined: Fri Jan 03, 2003 12:00 am
In addition, on big network broadcasting consoles, the same microswitches could also be configured to auto-cancel the channel's PFL mode, and unmute any pre-fade audience PA foldback sends.
Sadly, the days of faders opening towards the operator are long gone.
Posts: 39027 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Wonks wrote: Tue Jul 27, 2021 4:38 pm If you've got 100m drums, you're going to need some bloody long drumsticks! :D
And a gargantuan Persian rug! ;)
Posts: 4291 Joined: Mon Jul 21, 2003 11:00 pm Location: A studio deep in the fenlands of Cambridgeshire, UK
Search 16,966 SOS Reviews+Techniques articles: www.soundonsound.com/search
SOS Podcasts
Hugh Robjohns wrote: Tue Jul 27, 2021 6:04 pm Sadly, the days of faders opening towards the operator are long gone.
Just turn the mixer around 180° - instant nostalgia! :tongue:
Posts: 8845 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Some of my works | The SOS Forum Album projects
Post by RichardT »
And an elephant to hear the fundamental.
RichardT
Posts: 4191 Joined: Fri Aug 13, 2004 12:00 am Location: Ireland
Post by Dan LB »
Hugh, why do you say ‘sadly’? Do find reverse faders more intuitive or preferable in some way?
The option is there on a couple of Calrec Alphas that we have but I’ve never tried it. I must give it a shot sometime!
Dan LB
Posts: 1668 Joined: Sat Jan 28, 2006 12:00 am Location: Wicklow, Ireland
I found them much easier to use, especially when needing to open or switch between faders quickly.
Reversed quadrant faders were the best, ergonomically -- that up and over action follows the natural movement of the wrist very well -- but reversed flat faders are okay.
To open a fader to a set level, you just drop your thumb in front of the required fader level, and then use your 3rd/4th fingers to pull the fader up to the thumb. Fast, accurate and comfortable.
It's not as easy to place your 3rd/4th finger beyond the mark and push the faders up with a thumb. Possible, of course, but it's not as comfortable or easy to do, and I don't think it as accurate or precise, either.
For semi-static music mixes the faders direction makes little difference, but for a fast news or panel programme it really does!
And then there are other practical benefits, like not accidentally knocking a faders open with your jacket sleeve... ;)
Post by Rob Kirkwood »
Also gives you space to put your coffee cup.
Rob
Rob Kirkwood
Posts: 121 Joined: Tue Jan 07, 2003 12:00 am Location: Nottingham, UK
:shocked::o:shock:
I’ve got a red LED studio light, it’s only small, but it works, I’ve just never got around to wiring it up.
Posts: 16605 Joined: Sat Jul 12, 2003 12:00 am
Post by Music Wolf »
Hugh Robjohns wrote: Tue Jul 27, 2021 10:02 pm And then there are other practical benefits, like not accidentally knocking a faders open with your jacket sleeve... ;)
For the benefit of any younger readers who may have wandered in. This is how we used to lay down those sick beats back in the day.
Music Wolf
Posts: 2755 Joined: Fri Feb 17, 2006 12:00 am Location: Exiled to St Helens
Back in the day? Look into the studio and you can see Ed Sheeran! This is cutting edge technology.
Wonks wrote: Wed Jul 28, 2021 8:30 am Back in the day? Look into the studio and you can see Ed Sheeran! This is cutting edge technology.
We’ve got frosted glass on our studio door, the control room is in the basement, and the live room is upstairs, what I need is CCTV.
I'm nearly out of Brylcreem.... :lol:
Hugh Robjohns wrote: Wed Jul 28, 2021 9:40 am I'm nearly out of Brylcreem.... :lol:
A little goes a long way with you these days. ;)
Music Wolf wrote: Wed Jul 28, 2021 8:01 am
So presumably all these microphones are fully open? (Other than channel 8)
