New Korg Legacy instruments
Re: New Korg Legacy instruments
Happy it was useful :thumbup:
By way of additional info to the casual passer-by, this is the description I put on the SoundCloud track linked previously in the thread:
Eddy Deegan on SoundCloud wrote:This track contains 8 patches, 4 from the Korg Prophecy VST and 4 of the same name from the hardware SOLO-TRI card in my Korg Trinity .
There are four riffs, each of which is played twice from the same MIDI data. In each pair, the first is the softsynth and the second is the hardware.
There was no attempt to match the FX on the presets (I just used the ones they came with). I did not use any controllers other than pitchbend and aftertouch.
There has been no processing in terms of compression, EQ etc.
The first two riffs are played with the preset "Grungy", the second two with "Control Bass", the third pair with "Airworks" and the last two with "The Big One".
This is not intended to demo the capabilities of MOSS, just to contrast the hardware from 25 or so years ago against the software from today.
Listeners can draw their own conclusions!
Posts: 8853 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Post by Guest »
[ACCOUNT DELETED] wrote: Thu Jul 29, 2021 8:10 am Unfortunately I'm V1 so its $249, which I seem to remember was also the price from V1 to V2.
I was wrong, I can't even get an upgrade price. I have to pay full price.
Very strange as their is an upgrade price if you have the Special Collection ($149) and I have all the plugins that are in that collection!
I will email them and see what they say...
Guest
Post by BJG145 »
That's great Eddy, thanks for doing that. :thumbup:
If people want a "blind test", I've uploaded an alternative version where I've applied some normalisation and shuffled the order.
https://soundcloud.com/qchord/v2-1/s-wjLhXEe0ADZ
(To recap, these are four factory patches played on a Trinity MOSS card and Prophecy VST.)
I agree with your verdict; the fourth shows the potential though, and with a bit of tweaking you could probably get them pretty close.
Eddy Deegan wrote: Sat Jul 31, 2021 1:10 am I did a bit of research and it appears that the MOSS synthesis as implemented in the Korg Z1 involved quite a few more synthesis algorithms than the Prophecy VST does.
Interesting; it was high on the wanted list at one point. I wonder if they might give that one the VST treatment as well. They were always a bit underappreciated I think.
Posts: 7195 Joined: Sat Aug 06, 2005 12:00 am
Post by BJG145 »
Eddy Deegan wrote: Sat Jul 31, 2021 1:10 am ...the mapping of controllers to modulations is a bit different in places in the presets which I think is the main reason for the stark difference between the 3rd pair of riffs...
I'm interested in MOSS because it's Korg's version of Physical Modelling and should work nicely with breath controllers. It sounds like the hardware in the third section is responding to the expression data as "breath pressure" or "overblowing", whereas the VST seems to be interpreting it as a wide vibrato.
Gordon Reid wrote:The Z1's keyboard is sensitive to both velocity and aftertouch, and this is complemented by 12 dedicated controls (four filter knobs and eight envelope knobs), pitch‑bend and modulation wheels, and four foot‑pedal inputs. Unfortunately, a dedicated input for a breath controller is missing. This is a shame, especially when you consider how many wind instruments the Z1 seeks to emulate.
(The Z1 trumpet at 0.26 in this MP3 shows the potential of MOSS with a breath controller, as a purely synthesised sound reacting to pressure...no samples here AFAIK.)
Post by Tomás Mulcahy »
Thanks for doing that Eddie, very useful. It's a shame they didn't get the modulation or the effects (especially reverb) to match. The flute patch sounds quite silly on the VST, it's awesome on the hardware. It sounds just like that loaded in to my Trinity Rack MOSS (there's a Korg forum with the patches translated). Another reason to keep the hardware for another while yet. Maybe they need to get the original programmers on board such as Drew Schlesinger and Wiff. Although Drew gave it the thumbs up, he likes the UI and how clear the extensive modulation is. That's a very big plus over the Trinity Rack.
Tomás Mulcahy
Posts: 2568 Joined: Wed Apr 25, 2001 12:00 am Location: Cork, Ireland.
Post by BJG145 »
Tomás Mulcahy wrote: Sat Jul 31, 2021 1:41 pm It's a shame they didn't get the modulation or the effects (especially reverb) to match. The flute patch sounds quite silly on the VST, it's awesome on the hardware.
Is that the "Airworks" patch...? I just tried downloading the demo to see what it would sound like with breath pressure on the EWI. I didn't get close though.
https://soundcloud.com/qchord/airworks/s-NmF6yugEryR
You'll see that the UI has three wheels at the lower left. "Wheel 2" seems to control vibrato, and I think the expression data is probably driving that on the demo above. I reckon breath pressure should be set to drive "Wheel 3" instead. With that, I can hear a slight boost in the upper frequencies, but nothing like the octave switching in the hardware version. :thumbdown:
Did you do that on the VST? That's certainly an improvement. The over-blowing effect is one of the nicest things about that model.
Tomás Mulcahy
When I did it I was using aftertouch as the modulation source as that's the way it is on the SOLO-TRI. It does seem slightly odd to me that they'd implement that patch on the VST so much less usefully but it may well be possible to reprogram it. Maybe it was like that on the Prophecy hardware as well but I've no idea as I never owned one.
I avoided use of controllers other than pitchbend and aftertouch as the mapping from the Trinity physical joystick and ribbon is rather different to the mappings on the virtual Prophecy.
Post by forumuser909788 »
Hi,
A note to Eddy, if you haven't found it yet, there is a hold function in the program voice settings in the FX section.
Just wondered if anyone is having problems with the log (wheel 3). I am controlling the software with a hardware Prophecy and it all works fine in standalone mode. When I use it in Reason the log only responds when I move it away from me, not when I move it towards me and the ribbon doesn't work. It all works with mouse control.
I spent a couple of hours trying to sort it out and failed. I don't know if it's an issue with the VST or Reason. I'm a hardened midi user and all of the transmit / receive settings match.
If anyone is having the same issue in another DAW then I shall get in touch with Korg about it. I have already asked them if there is going to be any way of transferring sounds from the software into the hardware as that seems such an obvious omission.
If anyone out there is controlling the VST with a hardware Prof then I would love to hear if you have had a similar problem.
forumuser909788
Posts: 6 Joined: Wed Jul 06, 2016 10:58 am
forumuser909788 wrote: Sun Aug 01, 2021 11:15 pm A note to Eddy, if you haven't found it yet, there is a hold function in the program voice settings in the FX section.
So there is! I missed that. Thank you, and nice first post :wave:
forumuser909788 wrote: Sun Aug 01, 2021 11:15 pm If anyone out there is controlling the VST with a hardware Prof then I would love to hear if you have had a similar problem.
I was controlling it with the joystick on my Trinity which is spring-loaded to the centre point. Pushing the joystick generates CC#1 (normal modulation wheel) and pulling it generates CC#2 (breath controller).
I haven't used the VST in Reason, only in Studio One.
By default, CC#1 maps inversely to negative Y values on wheel 3 in the VST (ie: as you increase the CC values, wheel 3 moves 'down' from centre). I don't know what CC is required to move wheel 3 up though.
You can modify the MIDI controller mappings in the VST by accessing the global settings (via the little hamburger icon to the right of the preset name):
Through this I was able to assign a controller but this maps to the full range of movement on wheel 3 and you need a centre-sprung controller if you want to maintain the central default position of wheel 3 (if that makes sense). Also, assuming you're using a 7-bit controller then wheel 3 will most likely move in steps of 2 so you'll lose some of the range of expression (which may audible in certain situations).
As wheel 3 has a Y range from -127 to +127 I agree it's strange that there aren't two CCs configurable for it, one for positive and one for negative, especially as it seems likely that the default mapping is for two controllers.
Thanks for the info Eddy. I got a reply from Korg, saying that they have no plans to make sounds backwards compatible with the hardware.
I replied mentioning this wheel 3 problem. It just seems weird that you can define 2 controllers in the Arp page but only 1 in the global settings.
Reason can be a bit weird when it comes to controllers anyway. I shall post when I get a reply from Korg.
forumuser909788
Post by BJG145 »
For info, wheel 3 seemed to be driven by breath pressure on the EWI quite naturally.
Post by BJG145 »
OK, so...just taking another look at this. Breath pressure on the EWI drives wheel 3 by default, moving from centre upwards, and I'm pretty sure this is the "overblowing" mechanism, though even with the wheel moving fully upwards the overblowing sounds nothing like the hardware on "Airworks". It's very subtle. (Assuming that the hardware patch was "Airworks".)
Here's the readout from MidiOx showing what the EWI is sending when I vary breath pressure.
*edit*
Ignore the aftertouch, I've turned that off now, and the Breath CC moves wheel 3 on everything.
(If the strange vibrato patch was Airworks, and aftertouch is driving wheel 2, I'd be interested to hear the result if it could be remapped to drive wheel 3 upwards instead.)
Interesting; the B0 02 (Breath) CC messages were what I saw coming from the Trinity as well but they didn't move wheel 3 in the VST in Studio One.
I'll have another poke around at it later tonight or tomorrow.
Oh, yes, it was Airworks by the way.
Hi.
Having spent ages trying to figure out why Airworks didn't match I have realised that the pitch modulation is completely wrong on both the Reed and Brass models.
Applying any pitch mod just sounds like a standard oscillator, rather than introducing all of the harmonic changes of overblowing etc that you get on the hardware.
I also did loads of tests on the controllers, making sure that it wasn't me or Reason at fault. I can't get the log Dir - to work properly in Reason, although it works fine as a standalone.
I definitely think that Korg have messed up on the implementation of the log, hence only one Wheel 3 controller in the Global page. I let them know earlier. I shall get back in touch with my thoughts on the pitch mod and post when I hear something.
This would explain why some of my more industrial sounds, based on the physical models, are just silent in the software. I haven't checked the plucked string model yet. Time for my nap!
forumuser909788
Hi, just in case anyone is still waiting with bated breath, I haven't forgotten about this. The guy from Korg forwarded this to their software developers 2 and a half months ago and said that he would be in touch when he heard anything.
I chased recently but it's all gone quiet over there.
I have also had a few hardware exception errors when trying to route modulators. This happens in Reason but not in the standalone version. Hopefully they will be keen to sort this out as they offer Reason+ in their software bundle.
Anyway, I thought that I would just update anyone who, like me, really wants this software working properly. Ciao.
forumuser909788
Nice one - thanks for the interim update :thumbup:
I bought a hardware Prophecy in the meantime, but I do like the convenience and sound (not to mention the polyphony) of the VST as well!
