Recommend budget "dial-a-tone multi fx" to cover a covers gig
Hello kind people of the SoS forums
Recommendations most welcome for a cheap/budget (~£200/£250) guitar multi-fx to cover the tones necessary for a mostly 90s indie/rock covers gig. Cure (clean, reverb, chorus), Nirvana (distortion/fuzz), Pixies (gainy) etc.
Not much time or space to fiddle about with a pedal board, like I normally do. Would be great to have some kind of idiot proof box of the sounds I need to stomp between easily. Gig's likely to be cramped, chaotic (lots of guest singers), general madness.
Need to eliminate as many variables as possible!
Re: Recommend budget "dial-a-tone multi fx" to cover a covers gig
A used Line 6 M9? Picked up a second hand M5 recently, and very happy with the noises it makes.
- andy cross
Regular -
Posts: 191 Joined: Tue Apr 22, 2003 12:00 am
Will you tweak as you play, or do you see yourself as more moving through presets? (just saw the comment about cramped space)
If tweaking then maybe a used Line6 M13 would hits the spot?
The thing with the M13 is you have 12 scenes with up to four pedal emulations active, and each of those four can be a choice of three pre-selected fx. So you could probably set up a fairly good set of flexible pedal boards to cover both the songs you know you are doing and genre friendly pedal sets that you can call up for guests etc.
(Full disclosure I have one for sale at a good price if you did go down that route
- Random Guitarist
Frequent Poster - Posts: 1134 Joined: Tue Apr 01, 2008 12:00 am Location: West Sussex UK
I'll offer up my usual suggestion of either Digitech RPxx (50 or 55 are the chip-shop priced end of the range - I prefer the 50) or Zoom MS-50G (which can be 'hacked' to add effects blocks from the entire MS-ish range).
A Boss GT-1 is only £179.00 new, cheaper than the ME80 which is £229.00, and its sound engine is from the more expensive GT-100.
https://www.boss.info/us/products/gt-1/
- rockydennis
Regular - Posts: 142 Joined: Sat Nov 03, 2018 5:36 am
It's hard to go wrong with a Boss GT or ME but I have a Headrush Gigboard, it's a fair bit over budget but the interface is a virtual pedalboard on a touch screen, the sounds are excellent and it's very flexible and programable.
Forum Aficionado - Posts: 21959 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
I vote for the Digitech RP series
I have the RP360 and it covers a lot of ground. FX, drive, amp and cab sim etc
You can set it in preset mode to switch between sounds or use it as 3 discrete FX on / off per preset
There’s the option of adding an extra control pedal to do both functions at once, I think
Quite a lot of convincing recreations of specific track tones in the presets
I hate it when people post something slightly over budget but the Line 6 Pod Go would be ideal for what you're after. Best ergonomics in my opinion for ease of use and compact form. 4 snapshots for every preset which would be perfect for a covers band whilst keeping it simple on stage.
- Dynamic Mike
Longtime Poster - Posts: 5290 Joined: Sun Dec 31, 2006 12:00 am
Why do bad things mostly seem to happen to people who light up a room when they enter it?
jellyjim wrote: ↑Fri Jul 30, 2021 1:09 pm Hello kind people of the SOS forums
90s Indie Rock you say Jelly
I been watching vids of this 70squid indie multi fx pedal
Valeton Dapper Indie been considering getting it
https://m.youtube.com/watch?v=7pP-8G0OdXE
- tea for two
Frequent Poster - Posts: 4015 Joined: Sun Mar 24, 2002 12:00 am
TC Electronic Nova System. Compact, built like a tank, pretty easy to use.
£300 new, should be able to pick one up used for 50-60% of that?
- Music Wolf
Posts: 2866 Joined: Fri Feb 17, 2006 12:00 am
No One There
https://www.starbelly.me/
I use a Boss GT-001 desktop unit, but the floor mounted version, GT 100 is second hand on the usual places for £250 - £300 region.
Cannot fault the sounds for general use one bit and the variety of tones from clean to dirty is very impressive.
The acoustic sim on this is also good if you need that kind of thing at some point.
Great suggestions!
The Boss GT-1 seems like a good candidate bordering on a no-brainer.
The Internet's awash with user patches so somebody's probably already nailed the tones I need, it's £167 at GAK, GAK is a 15 minute walk away, and ... I won't lose too much money if/when I flip it on eBay, as it's not really the type of fx I'd normally use!
Thanks team. You are exemplary.
