Jam Origin guitar/MIDI conversion in MOTU Digital Performer
Post by Gone To Lunch »
We are having trouble using JO in MOTU Digital Performer 9.52. OS 10.13.6, with a MOTU 828 Mk3 Firewire.
In Stand Alone mode, JO latency reads as 256, but within DP it reads as 2048 with an over the limit warning, even though the 828 is set to 256. 2048 is twice the upper limit of the 828.
We have tried trashing the DP preference files as suggested by MOTU tech support, but makes no difference.
Gone To Lunch
Posts: 888 Joined: Fri Jun 11, 2004 12:00 am Location: London
http://www.gonetolunchmusic.com/
Re: Jam Origin guitar/MIDI conversion in MOTU Digital Performer
Does it work and at an acceptable latency for you? If so, then ignore the warning.
Posts: 11993 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Post by blinddrew »
Does it work ok as a standalone device or are you getting bad latency then as well?
Posts: 16161 Joined: Sun Jul 05, 2015 12:00 am Location: York
Midi Guitar V2.21? Using the VST rather than the AU version? Sample rate 44.1kHz?
Thanks for your replies.
We know it works stand alone, but the warning limit prevents it from operating at all in the DAW.
We don't really need live capability, just a reliable means of converting audio to midi - can you recommend anything else?
Gone To Lunch
If you've used the VST version (as Jam Origin recommend), is it worth just trying the AU version (if you haven't already)?
Wonks wrote: Sat Jul 31, 2021 6:11 pm If you've used the VST version (as Jam Origin recommend), is it worth just trying the AU version (if you haven't already)?
We have now tried both the AU and the VST versions, and the problem persists.
Gone To Lunch
Post by BJG145 »
Gone To Lunch wrote: Sat Jul 31, 2021 5:58 pmWe don't really need live capability, just a reliable means of converting audio to midi - can you recommend anything else?
I was blown away by this software last time I looked at it. I should persevere. Maybe try another DAW.
Posts: 5418 Joined: Sat Aug 06, 2005 12:00 am
BJG145 wrote: Sat Jul 31, 2021 8:42 pm
Indeed. But we don't have another DAW.
Their site includes detailed instructions for DP, so they clearly expect it to work therein.
Gone To Lunch
Post by G-Doubleyou »
Try GarargeBand
G-Doubleyou
Posts: 972 Joined: Fri Feb 10, 2006 1:00 am
2.3 GHz quad-core i7 Mini
Post by blinddrew »
Cakewalk is free on PC and Reaper is a free trial for PC and Mac.
If it works on one of those then you know it's not a problem with the JO download or with the rest of your set-up / routing.
blinddrew wrote: Sat Jul 31, 2021 10:18 pm Cakewalk is free on PC and Reaper is a free trial for PC and Mac.
It worked properly in Reaper.
Gone To Lunch
Post by wdsteele »
I have'nt t been using it much lately as I felt the latency was quite high , I put it down to whatever soft synth I was controlling in Logic and that seemed to change depending on the preset I selected in Alchemy or Kontakt Free.
I wonder if the result is the same using the included sounds .
My last impression was latency hsd been better on my older versions of Logic and OS , but may well have beern the type of sounds I was playing back then
, mostly slow attack pads anyhow.
wdsteele
Posts: 195 Joined: Mon Sep 11, 2006 12:00 am
Post by blinddrew »
Gone To Lunch wrote: Sun Aug 01, 2021 12:27 am
Hmm. Unfortunately that does rather stick the problem into the DP box, not something I know anything about I'm afraid. :(
Post by blinddrew »
wdsteele wrote: Sun Aug 01, 2021 8:56 am I have'nt t been using it much lately as I felt the latency was quite high , I put it down to whatever soft synth I was controlling in Logic and that seemed to change depending on the preset I selected in Alchemy or Kontakt Free.
I generally use the included sounds when tracking and then swap them out for my preferred options later.
