i have doubts and don't have possibility to test to see about this
a three way speakers which i dont find reviews for
or
mackie c200 which unfortunately is two way......
i listen at low volume .....15 db
what would someone wich dosent want too good or too bad do
three way speaker or two way mackie c200
- notsobadnotsogood
- Posts: 1 Joined: Sun Aug 01, 2021 11:17 am
Re: three way speaker or two way mackie c200
Can you give us a make and model number for the 3 way speakers?
Posts: 15869 Joined: Mon Sep 10, 2001 12:00 am
15dB isn't actually a volume, though you might mean that somewhere on your mixer or amplifier you have 15dB of gain (or is that -15dB of attenuation of the amp dial?).
But basically I assume you don't need a very loud speaker system.
What will you be playing through them, and what is your current set up? Is it recorded music or live music or speech etc? Presumably you already have a power amplifier (as the C200 is a passive speaker).
As you don't seem to be looking for a lot of volume, then are you looking for a good quality of sound? The C200s are towards the lower-cost end of the passive speaker market, so presumably you don't have a huge budget.
Your twitch is noted and shared...
Posts: 42186 Joined: Fri Jul 25, 2003 12:00 am
An old fogie responds...
Eh?
- Mike Stranks
Jedi Poster - Posts: 10585 Joined: Fri Jan 03, 2003 12:00 am
I think it’s similar to a suspected fox being in the henhouse..
- Mike Stranks
