Connecting multiple sources to 1 set of amplifiers, cheaply
Post by claz »
Hello, I have multiple sources that I'd like to connect to one set of tube power amplifiers.
I'm looking for a recommendation for a cheap and transparent source selector or aggregator, nothing fancy.
I already have a volume attenuator before the amp.
Most of the sources output via RCA cables (CD, LP, radio -- 5 total), so something that supports that natively would be ideal -- but I'm open to suggestion.
Is there any reason not to do this with multiple RCA-splitting cables -- but in reverse, so that all the Left channels eventually come down to a single left, and all the rights to a right?
Or a budget preamp? I'm hoping to stay in the $100 range, as I don't need a phono stage, and I don't want wireless connectivity.
There are various products on Amazon that purport to accept many RCA in, with 1 RCA out, but I'm somewhat suspect of their quality, perhaps unjustly. Hence my asking here.
Thanks for any thoughts.
claz
Posts: 110 Joined: Mon Sep 10, 2018 3:35 am
Re: Connecting multiple sources to 1 set of amplifiers, cheaply
Post by Mike Stranks »
I've used varieties of the 'Amazon' type multi-switchers on many occasions without issues.
You should be able to get one that works fine for about $10-$20...
... non-switched splitter cables are both cumbersome and unnecessary - and could cause audio quality and potential damage issues. Switcher not splitter! :)
Posts: 10585 Joined: Fri Jan 03, 2003 12:00 am
A cheap mixer, like this for example: https://www.gear4music.com/PA-DJ-and-Li ... -Mixer/2A8 , and some RCA to 1/4" jack converters like this: https://cpc.farnell.com/pro-signal/psg0 ... XcQAvD_BwE should do the job.
Posts: 28024 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by claz »
Thanks for the suggestions, admonitions, and confirmations!
claz
Post by Ben Asaro »
Without some sort of attenuation, line level sources going straight into a power amp may be very loud!
Ben Asaro
Posts: 2891 Joined: Thu Feb 26, 2009 12:00 am Location: NYC
Ben Asaro wrote: Mon Aug 02, 2021 6:27 pm Without some sort of attenuation, line level sources going straight into a power amp may be very loud!
claz wrote: Mon Aug 02, 2021 4:50 pm I already have a volume attenuator before the amp.
Looks like that’s already taken care of.
Posts: 18273 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
