When I try to use the search function I get the following message:
"Sorry but you are not permitted to use the search system."
I am logged in. I have cleared cookies and cache for www.soundonsound.com and soundonsound.com.
I'm using Firefox 90.0.2 on macOS 10.15.7 Catalina.
Any ideas?
Can't use search function
Re: Can't use search function
Hello jfry,
I cannot give you a definitive answer but I know a man who can and your post has been flagged for attention
Cheers and thank you for raising the issue. The forum software was upgraded to a newer version recently which may or may not be be related but as far as I am aware you are the first to report this particular problem.
Posts: 8851 Joined: Wed Sep 01, 2004 12:00 am
You're welcome, I've raised it as an issue for attention internally and you can expect an answer soon though it'll almost certainly be in UK office hours tomorrow!
Hi J
Because you have not yet exceeded the 3 post count, you are still in a moderation group which has different permissions. Search was blocked on your account but I have reset and activated it, for you and others.
So please log out and try logging in again and perform a search.
It will not work if you do not log out first, to clear cookies and set a new session.
- Forum Admin
Posts: 4291 Joined: Mon Jul 21, 2003 11:00 pm
