Hi there,
Does anyone have the USER instructions for these Spendors? I am trying to find the input sensitivity etc. I have the workshop manual but strangely this does not provide any technical or performance details for the monitor! Any help would be most appreciated.
Spendor SA200
Spendor SA200
- Mike Kershaw
New here - Posts: 5 Joined: Fri Aug 06, 2021 11:08 am
Re: Spendor SA200
I've had a google rummage and can't find anything from my usual sources either.
Paul White reviewed them here but doesn't give detailed specs or sensitivities beyond mentioning that it is adjustable.
Have you tried contacting the company directly?
Posts: 33750 Joined: Fri Jul 25, 2003 12:00 am
Re: Spendor SA200
Thanks for having a look around. Yes I contacted Spendor, but unfortunately they had a fire sometime in the past before the digital age and they only now have the maintenance manual which is devoid of any technical details other than the circuit schematics.
- Mike Kershaw
Re: Spendor SA200
FEATURES
Switchable HF and LF equalisation in 1dB steps
Response matched overload protection
Turn on delay and fast turn off cicuitry
Ferrofluid cooled HF unit, long throw LF unit
Full active filters matched to unit responses
SPECIFICATIONS SA200
Cabinet dimensions: 380mm x 220mm x 260mm
Cabinet weight: 12 kg
HF Drive Unit: 27mm soft dome, ferrofluid cooled
LF Drive Unit: 160mm polypropylene cone, 25mm coil
Sensitivity: -6 dB for 100 dB at 1 metre
Maximum SPL, short term: 106 dBA at 1 metre
Maximum SPL, music per pair: 114 dBA at 1 metre
Crossover point: 3.5 kHz
Frequency response, ± 3dB: 55 Hz to 23 kHz
Frequency response, ± 1.5dB: 65 Hz to 20 kHz
Pair matching: within 0.75 dB
Power amplifier, HF: 60 watts
Power amplifier, LF: 130 watts
Input connections: XLR 3 pin gold, IEC mains
- forumuser840717
Regular - Posts: 377 Joined: Thu Jun 16, 2016 5:20 pm
Re: Spendor SA200
Re: Spendor SA200
Many thanks, that's great. Cheers
- Mike Kershaw
Re: Spendor SA200
forumuser840717 wrote: ↑Sat Aug 07, 2021 12:45 pmFEATURES
Hi there,
Could I beg a further indulgence!
Have you any idea if the bass/mid unit was a "general" Spendor unit of the time? One of the pair is showing signs of distress way below maximum output ie distortion and hitting the end stop. The protection is not operating so it must be well below the design limits. If there is an easy swap for then I could keep them going for a while longer, or just have to use them at lower levels.
Many thanks in advance
- Mike Kershaw
Re: Spendor SA200
If it's distorting and hitting end-stops prematurely the implication is the spider/surround is failing. Your best bet is to contact Spendor directly to see what they suggest by way of replacement or rebuilding.
Re: Spendor SA200
Hi,
Thanks for the reply. I have had a look at the unit and couldn't see anything obvious wrong with the spider or surround. Spendor have suggested a re-build maybe through Wembley loudspeakers. At the moment I am going to keep an "ear" on the problem!
As an aside whilst I had the unit in bits I found the main Tx loose on the backplate so have tightened that up, tidied up the mains wiring routing, and also noticed that the main pcb doesn't match the service manual layout or circuit diagram so the minor additional irritant of a minor mains hum is not going to be as easy to fault find and rectify. Given their age they may just become a refurbishment project shame really as I was wanting to use them as a reference for some designs of my own.
Regards, M
Regards, M
- Mike Kershaw
