Korg Nu:Tekt NTS-1 as hardware FX unit?
Re: Korg Nu:Tekt NTS-1 as hardware FX unit?
Thats actually quite good. The '70 has stereo ins, so its good for synths but its delay based effects only. I like some of the amps and fuzz from the other models and have hacked a couple into my pedal. It was straight forward to do from PC. The only complication is deciding what delay FX to get rid of to make room and similar for deciding what to put in their place.
The USB also comes up in cakewalk as a MIDI device but Ive not found out what it does, if anything.
Posts: 4542 Joined: Sun Aug 12, 2018 2:40 pm Location: British Isles
Post by Ben Asaro »
For me, that’s a cinch: dotted 8th, done lol. :D
Ben Asaro
Posts: 2892 Joined: Thu Feb 26, 2009 12:00 am Location: NYC
BillB wrote: Sun Sep 19, 2021 1:49 pm Sadly I don’t have a Bluesky/Bigsky against which to compare,
maybe if you put up the dry version of your source material, some sky owner could process it 100% wet so you could make a comparison ?
Ben Asaro wrote: Sun Sep 19, 2021 3:22 pm For me, that’s a cinch: dotted 8th, done lol. :D
I like U2 so that not an option !
Post by BillB »
N i g e l wrote: Sun Sep 19, 2021 3:23 pm
Cool idea, Nigel :thumbup:
Ref Zoom CDR-70, that’s one of the pedals I want to compare against. Also a Behringer Reverb Machine RV600 and a Boss RV-6.
As for running two NTS-1’s in series, they are stereo in/out so no reason not to, but they are a fixed effects order: Mod>Delay>Reverb per box. But two together would give you a fair bit of mayhem!
Don’t forget, though - no memories, and knob positions are not ‘read’ (they can’t be, because the three knobs perform different functions for Osc, Filter, FX etc). So if you get a power blip, you are straight back to dry Sawtooth oscillator and no FX, until you start pushing buttons and spinning knobs. Most FX pedals will either allow you to reload a preset or will just read the knob positions, after a power outage.
BillB
Posts: 2199 Joined: Mon Apr 07, 2003 12:00 am Location: East Yorkshire
Post by Ben Asaro »
Oh, that’s a dealbreaker for me.
Ben Asaro
Post by Ben Asaro »
Ben Asaro
Post by BillB »
Ben Asaro wrote: Sun Sep 19, 2021 4:43 pm Oh, that’s a dealbreaker for me.
Thought it might be :(
Real shame that they couldn’t fit in a few memory slots.
BillB
Post by BillB »
Hmmm. This Retrokits RK002 cable changes things a bit, or opens up the possibility - but surely not viable for a minimalist live setup!
https://duy.retrokits.com/34b498da-a40b ... ca6437566/
BillB
RK002 is very clever. I've used it, for instance, to convert aftertouch messages to mod wheel.
Posts: 21008 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
BillB wrote: Sun Sep 19, 2021 4:40 pm
I have a CDR70, it’s very good for the money, a Swiss army knife that could be your only pedal, but, it can sound a bit small, it’s difficult to describe, but it doesn’t have that huge very dynamic sound of some of the more expensive units when you think it could actually be a real big space, but that’s not an issue if you accept it for what it is.
Posts: 19852 Joined: Sat Jul 12, 2003 12:00 am
Post by BillB »
I had a good listen last night to the Zoom CDR-70, Behringer Reverb Machine RV600 and a Boss RV-6, and compared them all to the NTS-1.
The headline is that if I could only keep one for reverb/ fx duties, it would be the NTS-1.
The CDR-70 certainly wins the award for most versatile unit, and that’s without doing any firmware hacks to make it even more versatile (see Elf’s postings on the CDR for more details). However, the basic sound of the reverb is not great, tending slightly towards metallic or grainy. The same is true of both the RV600 and the RV-6, although there is usually at least one setting where a fairly smooth effect can be obtained.
None of the above do that huge ambient Vangelis ‘sound of the city’ kind of reverb, whereas the NTS-1 does - or can. As noted previously, the HammondEggs reverbs can go from short through very long to infinite. The filtered versions are fun as an effect in their own right. Some folks may not be bothered about this kind of effect and will be perfectly happy with the above or other pedals. But as already stated, this unit really fills a gap for me. So much so that I am looking at other effects around the studio and thinking ‘an NTS-1 would probably do a better job there’.
Two other thoughts. It was fun to rig up the pedals and NTS-1 in series and go for a Ben Asaro ‘too much is not enough’ effect - it did result in massive ambience that had a character that no one unit could generate on its own.
The other is about patch memories. I’m not about to buy an Retrokits RK002 and a Novation Launchkey, just to get patch memories. But an iPad and MIDI Designer (both of which I already have) is a possibility. The CCs to control all NTS-1 parameters are simple enough and MIDI Designer can store 20 patches, so that would do the job.
All in all, it’s is not difficult to set up a repeatable sound patch for the FX directly on the NTS-1. If Osc, Filter, Env and LFO parameters were also to be recalled, that would certainly push my memory’s ability, but as I only really want the FX, it’s not much of an issue. I do expect to set up the CCs on a handy Novation Remote Zero - having all parameters on their own controls should make using the NTS-1 a breeze.
Hope that is of some interest and I will try to set up some sound examples on Soundcloud or similar, but don’t hold your breath.
BillB
Post by Ben Asaro »
BillB wrote: Tue Sep 21, 2021 11:26 pm It was fun to rig up the pedals and NTS-1 in series and go for a Ben Asaro ‘too much is not enough’ effect - it did result in massive ambience that had a character that no one unit could generate on its own.
Hey, I resemble that remark! :D
Great PS on this whole thread, very interesting, indeed!
Ben Asaro
Post by BillB »
Just thought I would report back. I did set up a Novation Remote Zero with the control CCs and it does make editing the FX very easy - although the only ‘shift’ function on the unit (for FX) is the 100% wet/dry balance achieved by holding down the Delay or Reverb button and turning the depth (knob 3) - so not difficult, even without a MIDI controller.
I compared the NTS-1 reverb (briefly) to a Bluesky pedal and a Lexicon Reflex, all plumbed into a little Mackie mixer. The NTS-1 holds up very well indeed, particularly for ‘modern ambient’ sounds that are a bit unreal and a bit grainy - not in a bad way, it’s just the character of the thing. Actually the built-in reverbs (Hall, plate) are pretty smooth, but don’t have long tails. I am loving the HammondEggs options. As I have now bought another NTS-1 to serve another keyboard sub-mixer, I owe HammondEggs a donation. Their add-ons really expand the NTS-1 FX palette.
I noticed that, with *very* sharp attack resonant sounds, it was possible to hear a rapidly repeating element to the sound of the HE reverbs - almost like a very fast mandolin pick effect. However, with anything other than very sharp attacks, all the HE models sound smooth. Maybe not quite so smooth and dense as the Bluesky or the Reflex, but really nice in its own way.
In summary, definitely something to look at if you were thinking about a reverb or multi-fx pedal in that price range, and don’t need it to be ‘stomp-able’.
BillB
Post by Ben Asaro »
Sounds like a successful round of experimentation! Thanks for following up!
Ben Asaro
