Not really a microphone for VO, I’ve only read of its use in a well treated ADR studio to match location dialogue at a typical boom to actor distance, not close up.
So I was able to find a local store that rents mics and have rented both the TLM103 and Manley Reference Cardioid for a week. I'm testing them out with my MixPre 3 II in the office room as well as my closet. While my office is not an ideal recording spot today, I am looking to either make it more ideal or record in another room like a walk-in closet (regardless of if I go dynamic mic or cardioid mic).
Additional thoughts welcomed and I'll keep you posted. Wish I had a way to rent a SM7B but that probably won't be possible.
If you can afford a Manley Reference Cardioid then you might as well just buy a Neumann U87 and be done with it. The U87 works acceptably well on just about any voice and is probably the nearest thing to an industry standard vocal mic. Once you've used it you'll recognise the sound from countless other recordings that you will have heard. You can also treat it as an investment - the value of a U87 seems to keep on going up.
Yeah those were just the two high-end mics that had available to rent from their used inventory. They are asking $1,900 for the Manley. They said they previously had a used U87 and that would have been nice to test with the others. The search continues...
No winter? I envy you Agree with James about the U87. It really is the standard.
An awful lot of stuff is done incorrectly in audio for picture and VO, because we see pics of it being done without being aware of the reasons or the science involved. Case(s) in point (a) overuse of shotgun mics (b) booths.
Agreed. Shotgun mics don't function well indoors without extremely careful setup as you describe. They're only ever used in ADR to make it easier to match the sound of the mic used on location. Even this practice I would question, personally. YMMV.
And I echo blindrew's point above about closets. A treated room is much much better.
So I've done some testing with the TLM103 and Manley Reference Cardioid in my closet recently. Feedback welcomed. They are both great mics! I do worry about the transformer setup and the tubes with the Manley though and what's involved maintenance-wise. These were recorded in my closet.
I know I need a better treated room for recordings but I'm not sure what's practical or possible where I currently live. Would love to get some thoughts on mobile solutions like the IsoVox (plus their IsoMic), Glide Gear Portable Isolation Sound Booth, Snap Studio Ultimate Vocal Booth, or even something like the Aston Halo in a reasonable space. Has anyone used these?
I can't help you with this exotic microphoni Sky but can perhaps allay your fears about valve reliability and replacement longevity?
Double triode valves are very long lived, decades for old Mullards in radios and audio kit. The 12AT7 used in the Manley Reference is the third most common valve of the 'big three'. The 12AX7, 12AU7 and 12AT7* in order of usage.
Another valuable property of valves is that they do not degrade, buy a couple of decent samples (they are ALL going to get vastly more expensive in a decade or two!) and put them somewhere safe and they will still be bang on original spec 20 years later.
Transformers are, if anything even more long lived. I stripped out a 1950 radio a year ago and the power transformer was still in perfect working order (OK, the output traff was shot but that was a regular fault back in the day anyway, valves used to bugger them)
*I have never understood why the 12AT7/ECC81 came to be used in audio gear? It was a television/oscilloscope bottle! But then, what do I know?
I thought both these recordings to be good and found no problem with them. The Manley recording was a little more "in your face" but not exceptionally so. Maybe it had a bit more bass timbre, or you were closer to the mic. I certainly found both recordings to be of a professional quality and a hell of a lot better than some of the examples one can hear on radio and TV (In the UK that is ...).
Agree with Ariosto. Both are fine recordings fit for production. There is a slight "hardness" that sounds to me like it's caused by a resonance in the mic stand or maybe a local reflection, such as from that corner.
Both sounded good but the Manley had (to my ears) a slightly exaggerated top end that initially sounds impressive but can be more wearing over time as it is can be down to a capsule resonance rather than a characteristic of the mic electronics.
Out of those two I'd save your money and go with the Neumann.
One other thing I noticed was the occasional popping 'P'. The best way to overcome this is to position the mic to one side or above your mouth so that your breath isn't going straight towards the mic.
Tomás Mulcahy wrote: ↑Wed Sep 15, 2021 6:12 pm
Yes, I agree totally. Also I think I would go with Jame's suggestion that the Neumann mic is fine and that the Manley could be a bit tiring over time, and of course it would be cheaper, always a good thing.
P S On listening again I actually prefer the Neumann mic as I think there is a slight edginess with the Manley. The Neumann seems smoother to my ear.
James Perrett wrote: ↑Wed Sep 15, 2021 10:32 pm
1. The TLM 103 is my go-to VO mic. Other great VO mics are M149 and U87 - but they can be a bit too 'warm' and they cost real money!
2. Use a pop filter on a gooseneck to avoid popping.
3. The TLM 103 really does need a treated room. In fact, the room will be the most important part of the overall sound.
4. The MKH416 is one of my other go-to mics for VO and not just to match production sound for ADR work. Last VO gig, I mixed the two.
skyace888 wrote: ↑Wed Sep 08, 2021 2:04 pm
Hi Experts,
I do voiceovers for tech videos (among other things) and am looking to up my game from my present setup. Currently have:
- Yeti Blue USB mic with boom arm and pop filter
- Untreated room/office in below image (carpet floor but computer fan noise and some street noise at times)
[url=https:*?*?*/wcqSvvh][/url] img upload free
- MixPre 3 II (used for non VO work on location presently)
- SM58 and other dynamic mics
Looking for suggestions on...
- How I might treat the room or if I should move my VO work to my walk-in closet. I am planning on remodeling the computer room anyways shortly.
- Which XLR mic might be most ideal. Top contenders are SM7B, TLM103, MKH416. I’m in South Florida and would love to test/rent these before buying. Plan would be to use the mic with my MixPre (either direct or as an audio interface)
Any other tips or suggestions greatly appreciated.
Thanks!
The MKH 416 is mainly for voiceovers for replacement dialogue that was originally made with a 416 or similar.
The TLM 103 is a good VO mic., as is also the U87. But I would also add the Gefell M930 to your list to try as it is superbe on speech and in the same price bracket as the 103 - there are several dealers in the US who may be happy to do a loan.
(Note - I distribute Gefell in the UK but have nothing to do with any sales in the US, or any other country)
Hanging a duvet behind you would improve the acoustics, and maybe also one behind the monitor screens.
Thanks again everyone. I’ve been doing more research and have plans to test various mics at studios in Denver and at the Sweetwater store in the coming weeks. Here is my latest list:
I recently had the opportunity to try a bunch of microphones on my list. Here are the sample files. I just normalized the levels in Audition but no other editing. Would greatly appreciate any feedback!
