Upgrading my VO Setup
Re: Upgrading my VO Setup
Post by skyace888 »
Yeah those were just the two high-end mics that had available to rent from their used inventory. They are asking $1,900 for the Manley. They said they previously had a used U87 and that would have been nice to test with the others. The search continues...
skyace888
Posts: 18 Joined: Wed Feb 03, 2021 10:30 pm
Post by Tomás Mulcahy »
No winter? I envy you :) Agree with James about the U87. It really is the standard.
An awful lot of stuff is done incorrectly in audio for picture and VO, because we see pics of it being done without being aware of the reasons or the science involved. Case(s) in point (a) overuse of shotgun mics (b) booths.
MOF wrote: Wed Sep 08, 2021 11:25 pm
too bad the MKH416 isn't available
Not really a microphone for VO, I’ve only read of its use in a well treated ADR studio to match location dialogue at a typical boom to actor distance, not close up.
Agreed. Shotgun mics don't function well indoors without extremely careful setup as you describe. They're only ever used in ADR to make it easier to match the sound of the mic used on location. Even this practice I would question, personally. YMMV.
And I echo blindrew's point above about closets. A treated room is much much better.
Tomás Mulcahy
Posts: 2811 Joined: Wed Apr 25, 2001 12:00 am Location: Cork, Ireland.
Post by skyace888 »
Thanks all.
So I've done some testing with the TLM103 and Manley Reference Cardioid in my closet recently. Feedback welcomed. They are both great mics! I do worry about the transformer setup and the tubes with the Manley though and what's involved maintenance-wise. These were recorded in my closet.
https://drive.google.com/file/d/1BJfKFu ... sp=sharing
https://drive.google.com/file/d/1RRNwUf ... sp=sharing
I know I need a better treated room for recordings but I'm not sure what's practical or possible where I currently live. Would love to get some thoughts on mobile solutions like the IsoVox (plus their IsoMic), Glide Gear Portable Isolation Sound Booth, Snap Studio Ultimate Vocal Booth, or even something like the Aston Halo in a reasonable space. Has anyone used these?
Edited to fix links - JP
skyace888
I can't help you with this exotic microphoni Sky but can perhaps allay your fears about valve reliability and replacement longevity?
Double triode valves are very long lived, decades for old Mullards in radios and audio kit. The 12AT7 used in the Manley Reference is the third most common valve of the 'big three'. The 12AX7, 12AU7 and 12AT7* in order of usage.
Another valuable property of valves is that they do not degrade, buy a couple of decent samples (they are ALL going to get vastly more expensive in a decade or two!) and put them somewhere safe and they will still be bang on original spec 20 years later.
Transformers are, if anything even more long lived. I stripped out a 1950 radio a year ago and the power transformer was still in perfect working order (OK, the output traff was shot but that was a regular fault back in the day anyway, valves used to bugger them)
*I have never understood why the 12AT7/ECC81 came to be used in audio gear? It was a television/oscilloscope bottle! But then, what do I know?
Posts: 18108 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Not working:
"Sorry, the file you have requested does not exist.
Make sure that you have the correct URL and that the file exists."
Tomás Mulcahy
Post by skyace888 »
skyace888
Post by Ariosto »
I thought both these recordings to be good and found no problem with them. The Manley recording was a little more "in your face" but not exceptionally so. Maybe it had a bit more bass timbre, or you were closer to the mic. I certainly found both recordings to be of a professional quality and a hell of a lot better than some of the examples one can hear on radio and TV (In the UK that is ...).
Ariosto
Posts: 920 Joined: Sun May 04, 2008 12:00 am Location: LONDON, UK
Post by skyace888 »
Thanks Ariosto for your feedback! Hope to test a few more microphones and then make a decision shortly.
skyace888
Agree with Ariosto. Both are fine recordings fit for production. There is a slight "hardness" that sounds to me like it's caused by a resonance in the mic stand or maybe a local reflection, such as from that corner.
Tomás Mulcahy
Both sounded good but the Manley had (to my ears) a slightly exaggerated top end that initially sounds impressive but can be more wearing over time as it is can be down to a capsule resonance rather than a characteristic of the mic electronics.
Out of those two I'd save your money and go with the Neumann.
One other thing I noticed was the occasional popping 'P'. The best way to overcome this is to position the mic to one side or above your mouth so that your breath isn't going straight towards the mic.
Posts: 15868 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by skyace888 »
Thanks guys. Yes I'll need to work more with the positioning of the mic. I was using a small, unstable mic stand for these tests.
skyace888
Post by Ariosto »
Tomás Mulcahy wrote: Wed Sep 15, 2021 6:12 pm Agree with Ariosto. Both are fine recordings fit for production. There is a slight "hardness" that sounds to me like it's caused by a resonance in the mic stand or maybe a local reflection, such as from that corner.
Yes, I agree totally. Also I think I would go with Jame's suggestion that the Neumann mic is fine and that the Manley could be a bit tiring over time, and of course it would be cheaper, always a good thing.
P S On listening again I actually prefer the Neumann mic as I think there is a slight edginess with the Manley. The Neumann seems smoother to my ear.
Ariosto
Post by The Red Bladder »
James Perrett wrote: Wed Sep 15, 2021 10:32 pm Out of those two I'd save your money and go with the Neumann.
1. The TLM 103 is my go-to VO mic. Other great VO mics are M149 and U87 - but they can be a bit too 'warm' and they cost real money!
2. Use a pop filter on a gooseneck to avoid popping.
3. The TLM 103 really does need a treated room. In fact, the room will be the most important part of the overall sound.
4. The MKH416 is one of my other go-to mics for VO and not just to match production sound for ADR work. Last VO gig, I mixed the two.
The Red Bladder
Posts: 3748 Joined: Tue Jun 05, 2007 12:00 am Location: . . .
Post by John Willett »
skyace888 wrote: Wed Sep 08, 2021 2:04 pm Hi Experts,
I do voiceovers for tech videos (among other things) and am looking to up my game from my present setup. Currently have:
- Yeti Blue USB mic with boom arm and pop filter
- Untreated room/office in below image (carpet floor but computer fan noise and some street noise at times)
[url=https:*?*?*/wcqSvvh]Image[/url]
img upload free
- MixPre 3 II (used for non VO work on location presently)
- SM58 and other dynamic mics
Looking for suggestions on...
- How I might treat the room or if I should move my VO work to my walk-in closet. I am planning on remodeling the computer room anyways shortly.
- Which XLR mic might be most ideal. Top contenders are SM7B, TLM103, MKH416. I’m in South Florida and would love to test/rent these before buying. Plan would be to use the mic with my MixPre (either direct or as an audio interface)
Any other tips or suggestions greatly appreciated.
Thanks!
The MKH 416 is mainly for voiceovers for replacement dialogue that was originally made with a 416 or similar.
The TLM 103 is a good VO mic., as is also the U87. But I would also add the Gefell M930 to your list to try as it is superbe on speech and in the same price bracket as the 103 - there are several dealers in the US who may be happy to do a loan.
(Note - I distribute Gefell in the UK but have nothing to do with any sales in the US, or any other country)
Hanging a duvet behind you would improve the acoustics, and maybe also one behind the monitor screens.
John Willett
Posts: 7297 Joined: Tue Mar 07, 2000 12:00 am Location: Oxfordshire UK
Post by skyace888 »
Thanks again everyone. I’ve been doing more research and have plans to test various mics at studios in Denver and at the Sweetwater store in the coming weeks. Here is my latest list:
Austrian Audio OC818
Gefell M930
Warm Audio WA87 R2
TLM103
U87ai
Soyuz 017 FET
Josephson C705
Lauren Audio Atlantis
Thoughts welcomed. I’ve used Audio Test Kitchen which has most of these but no vocal samples. Also tough to tell even with studio monitors.
skyace888
Post by MOF »
You could have a look at the Sontronics range.
MOF
Posts: 2472 Joined: Thu Mar 06, 2003 12:00 am Location: United Kingdom
Post by skyace888 »
Hi All,
I recently had the opportunity to try a bunch of microphones on my list. Here are the sample files. I just normalized the levels in Audition but no other editing. Would greatly appreciate any feedback!
https://drive.google.com/drive/folders/ ... sp=sharing
skyace888
Just had a quick listen and the first thought is that all of them, unsurprisingly, deliver a perfectly useable result. To my ears at any rate.
I think if I had to state a preference I'd maybe nudge to the Soyuz or the U87, they seemed to deliver a brighter sound without overemphasising the esses (which I felt the TLM and OC818 did).
Better people may be along shortly to correct me. ;)
Posts: 28055 Joined: Sun Jul 05, 2015 12:00 am Location: York
As Drew says, they are all perfectly usable.
To me, the Gefell M930, Neumann TLM103, and OC818 all have a slightly brighter character which is probably advantageous for a commercial recording, although I dare say they could all be softened a little, if required, by changing the position/angle.
The U87 is a more mid-forward. I didn't like the C705/716 mics -- they seemed a little fierce on that voice.
Without knowing the tonality of the voice in person it's impossible to say which is the most accurate or flattering.
Posts: 42179 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Told you! :D
Post by skyace888 »
Thanks guys for the quick replies.
To confirm, the voice you hear is my voice and I will primarily be using this microphone.
Yes all of these mics are quality. I agree that the Josephson mics don't seem like a good fit (plus for the C705 it wasn't too sensitive so the gain really needed to be cranked up on my recorder). I think I'll rule them out.
The U87ai is a timeless classic but I don't think I can reasonably afford one at this time (even used).
That leaves...
-OC818
-TLM103
-M930
-Soyuz 017
Will research further and maybe get another go to test these at another dealer. I'm sure I can't go wrong with any of them.
skyace888
