New Hydrasynth Models
Not really my kinda thing, but should interest a few people here:
Good to see 'Polytouch' above that keyboard, though...
Posts: 21008 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
that looks cute :)
Posts: 4542 Joined: Sun Aug 12, 2018 2:40 pm Location: British Isles
Post by nathanscribe »
They're doing a 73-note semi-weighted poly AT model as well...
nathanscribe
Posts: 1542 Joined: Fri Jan 19, 2007 12:00 am Location: Wakefield, for my sins.
nathanscribe wrote: Thu Sep 09, 2021 6:30 pm They're doing a 73-note semi-weighted poly AT model as well...
Ooh! Now that's the one! I won't care a jot what it sounds like - I'll only be using it a controller keyboard! :lol:
Anyone want to buy a never-gigged Hydrasynth?! :lol:
Re: New Hydrasynth Models
The Elf wrote: Thu Sep 09, 2021 6:56 pmhttps://youtu.be/ieU4yEWHyKI
Bi-timbral, it seems.
The Elf wrote: Thu Sep 09, 2021 6:58 pm
That deluxe is lovely isn't it. It's definitely on my shopping list for early next year :thumbup:
Posts: 9590 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
I'd have been happy with a 5-octave keyboard, but a six-octave works too, especially with the split modes, and 16 voice is very tasty. If it turns out to be affordable it might well scupper much of the latent interest in B's DS80 plans.
Posts: 42149 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
I'm reading...
Shipping in November
$599/£549/€599 for the Explorer.
$1,799/£1,699/€1,749 for the Deluxe.
All I (still) want now is sticky Local Off...
Post by pilot-wave »
Waited patiently two years for a 5-octave follow up, then a month ago, thinking it wouldn't happen after all, I capitulated and got a new 49 key original... now it decides to turn up with another octave on top of that!
Would've been nice to have an integrated multi-lane sequencer instead of the arpeggiator, but other than that it appears to be what I would have preferred in the first place but with very welcome additional doubled polyphony, layering, splits, outputs etc, so, one way or another, this will be purchased.
pilot-wave
Posts: 131 Joined: Tue Sep 06, 2005 12:00 am Location: Gloucestershire: UK
I like the layers and splits. I wonder if the multi timbrality will trickle down to the 49 key version.
I don't think that would make economic sense to ASM. And the Deluxe probably has more processing power (two of the older model's processing chips?) to generate the additional voices. So the architecture itself may not support splitting.
But I know nothing more than anyone else outside of ASM, and I've been proved beneficially wrong many times. :D
I do hope I can find my way onto an early order list, because with gigs once again in the offing I'd love to have that wide poly aftertouch keyboard along with me.
Dont count your Hydrasynths before the're delivered ! - what with the global shipping situation and everything.
I was thinking that the Prologue exists in 2 models, as 16 or 8 voices and is bi-timbral, so why not the Hydrasynth ?
Also Novation with the Summit, which is basically 2 Peaks in a single instrument with some additional controls for splits/layering and edit modes for one, other or both of them.
The use of different coloured LEDs on the interface to let you know which mode you're in works really well in the Summit and makes perfect sense for the Hydrasynth.
I also like that the patches on the Deluxe are fully compatible with the original Hydrasynth and the ability to straightforwardly mix-n-match any two of them on the Deluxe is very elegant.
N i g e l wrote: Fri Sep 10, 2021 3:01 pmI was thinking that the Prologue exists in 2 models, as 16 or 8 voices and is bi-timbral, so why not the Hydrasynth ?
Maybe you're right. But I doubt it. As above - Peak and Summit are a good example.
Post by tea for two »
The Elf wrote: Thu Sep 09, 2021 4:21 pm
Dear Ashun and Glen see this, just making it into a
Sampling Workstation
with
*10inch Touchscreen, Vocoder, Quality Dual Combo inputs (xlr and trs), Balanced outputs, Usb out.
*Keeping it Battery powered and Usb portable battery powered.
*Keeping PolyAT. Keeping 37keys.
*Enabling recording on a separate internal  tiny 1TB m.2 ssd that's easily replaceable.
*Sound import via Usb and Sd card and saving to them.
*Adding Korg Kaoss Mini style dynamic processing pad.
(Removing Synth engine frees up enough associated real estate).
Dear Ashun and Glen, I get the feelz it would sell as Hot Cakes amongst DJs EDM, HipHop producers, Beatz makerz, YouTube musicians, Electronic musicians, Musicians on the go in several genres.
Freeing them up from Macbook, current MPC, Laptop.
Freeing them up from having to carry several gear.
As you are aware, no manufacturer has done this. I've been waiting since Korg MicroSampler (2009).
Tech wasn't ready before, it is ready now.
It is such an obvious product yet
It would unique.
It takes a smaller company as yourselves to be innovative Dear Ashun and Glen.
tea for two
Posts: 4015 Joined: Sun Mar 24, 2002 12:00 am
The Elf wrote: Fri Sep 10, 2021 3:51 pm
Im not saying right or wrong - Im just guessing whats possible from an uninformed {but perhaps logical?} standpoint.
The 'logue voice cards are 4 voices per card {bi-timbral},
the blofeld is just 1 DSP to do everything {16 timbral},
Ion/Micron/Miniak are 1 special chip per voice {8 timbral}
those facilities do the hard graft of generating sound but milti timbrailty, the act of setting up different sets of synth parameters, recognising MIDI/kb zones and allocating notes to voices seems a less onerus & time consuming task by comparison.
I note that the Hydrasynth16 has buttons for multi mode, which is nice & elegant. I was thinking of a work flow more like the Prologue, which achieves bi-timbrailty via the sub menus of the buttons that have no legend*.
thinking about that, it may be that ASM dont want such an inscrutable asthetic.
*mine has got appropriately annotated mixer scribble strip console tape.
Post by t-sun »
Just saw these, the little one is on my list for sure. Poly Aftertouch on semi-weighted mini keys? I have to have one just to see how any of that sentence works :lol:. My only poly aftertouch keyboard is a spotty VFX-SD, and frankly given everything about the spec on this it seems like the whole line is aimed right for that. The array of I/O on the back of the Explorer is superb too.
I'm drooling at the specs on the Deluxe, but it's out of my price/space range and besides, I looked at the back and was immediately disappointed. A 73-key full size keyboard and they're still running it on a WALL WART! Will we ever get internal power supplies again? Can't some company come up with top quality 5v, 9v and 12v internal supplies with IEC sockets that can be sold wholesale as off-the-shelf parts to synth makers or something? I realize they're intended to be easy to replace (and save manufacturing costs, but come on it's $1800!), but there is no such thing as a well isolated wart.
t-sun
Posts: 264 Joined: Mon Jan 18, 2021 6:31 am
t-sun wrote: Sat Sep 11, 2021 2:14 amA 73-key full size keyboard and they're still running it on a WALL WART!
I'm with you. I think it's a disgrace when gear at this level is saddled with an external PSU. I didn't fail to notice in the video how thin the power cable was, either. Is this pro gear, or a toy?
My plan with my current Hydrasynth was to get the PSU mounted inside the case, but lockdown overtook me. When I get my Hydraynth Deluxe that will again be my plan. I've had external PSUs placed inside on several of my devices and it makes them more suitable for gigging. I've pretty much resigned myself to having to do this more often.
Post by jjlonbass »
t-sun wrote: Sat Sep 11, 2021 2:14 am I'm drooling at the specs on the Deluxe, but it's out of my price/space range and besides, I looked at the back and was immediately disappointed. A 73-key full size keyboard and they're still running it on a WALL WART! Will we ever get internal power supplies again? Can't some company come up with top quality 5v, 9v and 12v internal supplies with IEC sockets that can be sold wholesale as off-the-shelf parts to synth makers or something? I realize they're intended to be easy to replace (and save manufacturing costs, but come on it's $1800!), but there is no such thing as a well isolated wart.
Yes, off the shelf power supplies like this are available. Indeed, very few manufacturers of equipment like a synth would design their own power supply, instead they would source a standard or custom PSU from the many manufacturers of such things.
The justification for not doing this is that equipment with built-in mains power supplies has to undergo more extensive compliance testing than equipment that is powered from a low voltage. This is true regardless of who made the built-in PSU - it is the entire system that has to be tested. This testing takes time and costs a lot of money. Either the manufacturer pays and reduces their profit margin or the consumer pays a higher purchase price.
jjlonbass
Posts: 114 Joined: Wed Dec 19, 2018 3:52 pm Location: Ware, Hertfordshire UK
jjlonbass wrote:The justification for not doing this is that equipment with built-in mains power supplies has to undergo more extensive compliance testing than equipment that is powered from a low voltage.
...and so they should knuckle down and do it, instead of saddling us with this external PSU nonsense.
I'm prepared to pay extra, so give me the option.
I've seen all kinds of justification for external PSUs and none of it washes with me. It's about saving money - plain and simple.
While most of the world seems not to care, or is happy to explain it away, and even justify it for them, manufacturers will continue to save the pennies and smile as they take our money.
Post by jjlonbass »
I agree, it is all about money and I'm not too keen on wall warts either.
I just wanted to explain why equipment is often designed to use a wall wart.
I've designed some low volume production electronic equipment and this had to use an external PSU as we simply couldn't justify the cost of mains voltage compliance testing for the expected sales volume.
jjlonbass
No worries, John. I wasn't targetting you. :thumbup:
This is my bi-monthly external PSUs rant. The regulars here are used to it. Glad to meet someone of the same mind. :D
Post by Ben Asaro »
The baby Hydrasynth may push me over the edge, I've heard so many good things about that synth engine.
Ben Asaro
Posts: 2891 Joined: Thu Feb 26, 2009 12:00 am Location: NYC
