New Hydrasynth Models
Re: New Hydrasynth Models
Post by S.Crow »
The Elf wrote: Sat Oct 30, 2021 12:55 pm ...right up until USB-D arrives! ;)
They do keep updating the power delivery specs, which means you have to make sure you use a cable rated for the power delivery required.
"USB Power Delivery offers the following features:
Increased power levels from existing USB standards up to 240W.
New 28V, 36V, and 48V fixed voltages enable up to 140W, 180W and 240W power levels, respectively.
An adjustable voltage supply mode allows the device being powered an ability to request intermediate voltages between 15V and up to the maximum available fixed voltage of the charger."
S.Crow
Posts: 358 Joined: Sat Apr 03, 2021 4:34 pm
Post by BigRedX »
The big problem with using USBC for power delivery on audio equipment is that the connectors simply aren’t robust enough for a gigging environment.
BigRedX
Posts: 2818 Joined: Fri Sep 03, 2004 12:00 am
BigRedX wrote: Sun Oct 31, 2021 5:11 pm The big problem with using USBC for power delivery on audio equipment is that the connectors simply aren’t robust enough for a gigging environment.
I'm sure Neutrik could engineer a solution to that (if they haven't already).
Ah - they have
https://www.neutrik.com/en/neutrik/prod ... s/mediacon
Posts: 15901 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by rACed2 »
The Elf wrote: Thu Oct 28, 2021 9:02 am
rACed2 wrote: Wed Oct 27, 2021 11:19 pm So has anyone got delivery of a Delux yet?
The last communication I received told me that despatch had been brought forward from 10th December to 22nd October, but so far... nothing.
Any change?
rACed2
Posts: 160 Joined: Mon Apr 15, 2013 12:00 am
Organ, synth’s x2 Not enough time or talent.
No further communications received and still nothing arrived yet.
Posts: 21028 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
