Before I buy, I’m trying to learn: where will the SPDIF inputs 9-10 appear? In the mains? In the headphones? Both?
Thanks!
Behringer UMC1820 SPDIF inputs
- skyrider82
- Posts: 1 Joined: Wed Sep 15, 2021 1:39 am
Re: Behringer UMC1820 SPDIF inputs
skyrider82 wrote: ↑Wed Sep 15, 2021 1:48 am Before I buy, I’m trying to learn: where will the SPDIF inputs 9-10 appear? In the mains? In the headphones? Both?
Thanks!
AFAIK, those inputs are just like any other, they should appear in both.
Maybe someone could confirm this. I have an 1820, and can’t remember having these issues.
Thanks!
if to "access" it means hearing the input, then it just has to be activated inside your DAW and routed to the main outputs inside the DAW, which would of course represent "1-2" on the headphone outs.
I've read through the manual, and there's no non-DAW way to route it, i.e., some simple, light software to manage inputs, if that's what you're looking for.
Hope this helps!
- wearashirt
Regular -
Posts: 124 Joined: Wed Jun 09, 2021 4:18 am
