Anyone finding Reaper 6 a bit sluggish?
Post by Mixedup »
As above. Thought I'd try it out to see what I was missing. I'm on Mojave, on a MacBook Pro, a setup which has worked fine with previous versions. But the v6 is glitching a lot — graphically, with as much as a second pause to catch up with mouse movements making it almost unusable. Equally interested in experiences on Win or other Mac OS, hence posting here...
Mixedup
Re: Anyone finding Reaper 6 a bit sluggish?
I've been running 6.29 on Win 10 without any obvious problems (and definitely no sluggishness) for a while, and am just downloading 6.36 now...
Posts: 42172 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
I always update as and when any notifications come in, so am currently on 6.36 on Windows 7.
No slowdowns noticed at all, and I'm using Reaper on a daily basis.
Posts: 21642 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Post by Lophophora »
Same as Martin Walker here.
Lophophora
Posts: 85 Joined: Thu Sep 15, 2016 2:28 pm Location: Singapore
Jean-Marc
SoundWise Mastering
Another 6.36 on Windows user here with no problems. Don't recall any glitching with the earlier versions of 6 either.
Posts: 28039 Joined: Sun Jul 05, 2015 12:00 am Location: York
I upgraded to 6.36 a few days ago (from 6.29) a few days ago and haven't noticed any issues. However, I've noticed in the past that it can get very slow if you are using a few convolution reverbs at high sample rates with large multitrack sessions of 24 tracks or more.
Posts: 15859 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by BWC »
James Perrett wrote: Tue Sep 21, 2021 12:43 am However, I've noticed in the past that it can get very slow if you are using a few convolution reverbs at high sample rates with large multitrack sessions of 24 tracks or more.
...compared to doing the same with other DAWs using the same machine?
BWC
Posts: 869 Joined: Thu Apr 29, 2021 9:12 am Location: FL, US
BWC
Post by Zukan »
AA plugs Matt or general sluggishness?
Zukan
Posts: 10084 Joined: Fri Sep 12, 2003 12:00 am
'Shaka. When the walls fell. Zukan...with his arms wide.'
Samplecraze
1-2-1 Tuition
Zukan wrote: Tue Sep 21, 2021 8:32 am AA plugs Matt or general sluggishness?
Yes, check your plugs.
I’m on the latest version, always update, I’m running it on Mac High Sierra, and Win 10, no problems.
Posts: 19866 Joined: Sat Jul 12, 2003 12:00 am
Post by Mixedup »
Thanks guys and gals. Latest version of Reaper. No AA or convo plugins. Only four audio tracks in the session. Could be plug-in related, though I've installed nothing new and the session was created and working fine in the latest v5. If/when I figure it out I'll report back but obvs don't want to name/shame plug-ins here if they're not at fault!
Mixedup
BWC wrote: Tue Sep 21, 2021 1:08 am
I expect other DAWs would be as bad or worse. It was surprising how much difference doubling the sampling rate made.
Post by BWC »
James Perrett wrote: Tue Sep 21, 2021 4:29 pm
OK, I'd be disappointed to hear of Reaper under-performing with such things, relative to the others, as I'm generally so impressed with Reaper's capabilities.
James Perrett wrote: Tue Sep 21, 2021 12:43 am It was surprising how much difference doubling the sampling rate made.
Makes sense, that's a lot of extra work for the old central calculator.
BWC
BWC
