Yet another sampling frequency question
Re: Yet another sampling frequency question
Post by The Red Bladder »
I get where you're coming from, but this is something of a misleading exaggeration. There is a very large number of 'studio mics' that have a response which extends well beyond 20kHz.
They pretty much all do because if there is a cap, it'll be just passive - so still stuff going on at 30+ though usually rather uneven F response. (I like misleading exaggerations - it's one of my specialities!)
The Red Bladder
Posts: 3746 Joined: Tue Jun 05, 2007 12:00 am Location: . . .
It is interesting that there is often plenty going on above 20kHz on many of the tapes that I transfer - especially with some DI'd analogue synth sounds.
Posts: 15852 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by RichardT »
James Perrett wrote: Tue Sep 21, 2021 4:19 pm It is interesting that there is often plenty going on above 20kHz on many of the tapes that I transfer - especially with some DI'd analogue synth sounds.
The same is true of software synths- sometimes huge amounts > 20kHz
RichardT
Posts: 4975 Joined: Fri Aug 13, 2004 12:00 am Location: UK
Post by Stig Ø »
Thank you all for your replies - I really appreciate it. I think I’ll keep going at 44.1, but as several of you have mentioned, it’s a fairly simple thing to test at different rates. I was basically after the theoretical reasons for changing or not, and you’ve all contributed to the discussion in that sense. Maybe 48 could be a happy medium, who knows? I’m running Logic on a 2015 iMac with an i5 cpu and 16GB of RAM. It keeps up nicely with my projects, which apart from Superior Drummer are all audio files. Nothing fancy in the processing department - just reverb, compression, eq - standard stuff. I think it would be able to cope with 96, but, as mentioned, maybe 48 is good enough (whatever that means for a hobbyist).
Are there any special advantages with recording at 88.2, as it’s a straight doubling of 44.1, or will the points mentioned already apply to that f/s as well?
Again, thanks for taking the time.
Cheers, Stig
Stig Ø
Posts: 76 Joined: Wed Jun 16, 2021 8:21 pm
I make guitar noises
Stig Ø wrote: Tue Sep 21, 2021 5:40 pmAre there any special advantages with recording at 88.2, as it’s a straight doubling of 44.1, or will the points mentioned already apply to that f/s as well?
The points re 96k apply.
The 88.2 sample rate isn't really used by anyone as it offers no advantages. A couple of decades ago when sample rate converters weren't great it was easier to work at 88.2 and then use a 'synchronous' converter to create a 44.1 file for CD mastering.
But these days there are no synchronous converters. They are all 'Asynchronous' which means the actual sample rate doesn't matter... and 96kHz has become the defacto standard for double-rate work.
Posts: 42144 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by Stig Ø »
Good to know - thanks again.
Stig Ø
