Mastering from tape to digital rig question
I’m trying to hook up a revox A77 1/4 inch and get it into my pro tools via an Avalon 96k interface.
I’m wondering what leads I need with minimal interference? Stupid question I know. The Avalon only takes XLR input I think. Ordered it but it hasn’t come yet so
Need to confirm.
Sent from my iPhone using Tapatalk
Need to confirm.
- hannahjazzz
Poster - Posts: 36 Joined: Wed Apr 24, 2019 1:13 pm
Re: Mastering from tape to digital rig question
I'm a little confused - I can't see any audio interfaces in Avalon's product range. Or is there a different Avalon company that Google doesn't know about?
It would help if you could give us the make and model number of all the devices that you are using in your signal path.
Posts: 12857 Joined: Mon Sep 10, 2001 12:00 am
I'm not aware of any DAW audio interface made by Avalon, so can't offer any advice on its connectivity. Can you share a link to the specific product, please?
And what are the available output connectors on your specific model of Revox A77. I've seen some with RCA-phono (cinch) and/or DIN connectors, and others with XLRs.
Posts: 35436 Joined: Fri Jul 25, 2003 12:00 am
Having refreshed the old brain, the A77 has both RCA phono and DIN ('radio') outputs but the DIN is via a 4k7 resistor and attenuated by at least 6dB. The RCA output looks to be low source resistance at ~400 Ohms.
I would therefore suggest a simple RCA to 1/4" TS (guitar) jack cable as it would be a strange interface that did not have jacks?
But yes, give us the full SP!
The 'radio' connection conformed to the old DIN hi-fi standard which evolved with valve equipment and passed the signal as a current, rather than a voltage.
The equivalent input voltage when connected to modern voltage-fed equipment is entirely dependent on the device's input impedance, at a nominal 1mV/ 1k Ohms.
So 100k Ohms input impedance gives 100mV signal level.
Hugh Robjohns wrote: ↑Wed Sep 22, 2021 4:50 pm
Yes Hugh, a lot of people slagged off the DIN connection standard but they did not understand it and it was entirely appropriate for valve based equipment in 'domestic' circumstances. 'Pros' of course could afford cathode follower stages and transformers!
I was in fact expecting a much higher resistance than 4k7? I guess because of the transistors they, like so many others went 'half way'.
The A77 was Revox's first transistor model (all silicon) and an excellent machine. I've never seen one with XLRs though. Output level is adjustable at the front panel.
- Tim Gillett
Frequent Poster (Level2) - Posts: 2555 Joined: Wed Jan 30, 2013 12:00 am Location: Perth, Western Australia
Revox themselves didn't make any with XLR's (as far as I know) but various third parties modified them to add balanced inputs and outputs on XLR's.
The A77 tape machine was intended as a domestic/consumer hi-fi product and came with RCA-phono and DIN connections as standard. But the machine became a popular low-cost alternative to professional studio recorders and many were 'studio-ised' which included retrofitting XLRs -- at least in the UK and Europe.
Hugh Robjohns wrote: ↑Thu Sep 23, 2021 9:44 am
Yes, not surprised as they were more compact and much lighter than the Studer equivalents. I believe their much greater portability and general audio quality made them popular for location live to stereo concert recordings on 10.5" reels. Onboard Dolby B was an option, making for potentially even better quality live recordings.
- Tim Gillett
Alfred Brendel used an A77 to listen back to his practice.
Trevor Johnson wrote:Yes, not surprised as they were more compact and much lighter than the Studer equivalents. I believe their much greater portability and general audio quality made them popular for location live to stereo concert recordings on 10.5" reels.
Thanks for your response. Would I be wasting my time using a revox with my 1/4 inch tapes to transfer them to digital? I
- hannahjazzz
