Thanks for everyone's help. I appreciate it.
Explanation was crystal clear Wonks, and I might have known Martin W would still have had his
So, the one in the link is out, as the barrel is 5.5mm ?
https://www.acadaptorsrus.co.uk/replace ... y-150-050/
I'm borrowing a Multimeter today. If the news is bad, I'll look for something with the right specs.
Replacement PSU for M Patch 2 Monitor Controller
Re: Replacement PSU for M Patch 2 Monitor Controller
Forum Aficionado -
Posts: 24658 Joined: Sun Jul 05, 2015 12:00 am
As Martin mentioned ‘most PSUs’, then I’m pretty sure he meant 5.5mm, not 5mm. 5.0mm is certainly not ‘usual’, and is going to be pretty rare.
Most of the ones I've used are 5.5mm for the outer barrel diameter.
Posts: 39036 Joined: Fri Jul 25, 2003 12:00 am
porthoss78 wrote: ↑Tue Oct 05, 2021 9:09 pm Hi,
If it does turn out to be the PSU, give these a call/email:
https://myvolts.co.uk
They just need some information about the existing PSU and a photo of the PSU socket (or they did with my PSU replacement for an old Korg).
Hope that helps
J
I've used these guys and happy to second the recommendation. Not the quickest service but good quality products and great communication.
- Dynamic Mike
Frequent Poster - Posts: 4698 Joined: Sun Dec 31, 2006 12:00 am
Keeping 2 Chevrons apart
I seemed to have solved my problem.
Bad news: I have an old one disk WD My Cloud which bricked it self yesterday.
Good news: I took a look at the adapter, and it was well within the specs. So all is well, and I have my lights and HPhone socket back.
Thanks for everyones' help
And a from me as well.
Saved you at least a tenner anyway
