Hi Guys
I want to make a custom size Skyline style diffusor from wood for my studio. I can't seem to find a straight answer on the design i.e how to lay out the wood blocks and what length ?
Would anybody know a good calculator for this please ?
Matthew
SkyLine Diffusor Calculator Question ??
- Matthew Seed
Regular - Posts: 394 Joined: Mon Dec 18, 2006 12:00 am
Re: SkyLine Diffusor Calculator Question ??
A good place to start is probably here: http://downloads.bbc.co.uk/rd/pubs/reports/1995-01.pdf
Posts: 34079 Joined: Fri Jul 25, 2003 12:00 am
blindrew of these forums has built a couple for his studio (and very nice they look too), so will probably be along in a minute with helpful DIY advice.
Posts: 19118 Joined: Wed Jan 13, 2010 8:44 am
Ha! I think the only advice I can add is to work out how much wood you need, double check, double check again. Be prepared to be slightly mind-boggled at how much is actually required for a reasonably modestly sized diffuser.
If you take the example in the paper Hugh linked to, of a 2' by 2' (or 60cm in new money) with a maximum depth/protrusion of 20cm. You're looking at 12x12 grid of 2" timber with an average length of 10cm. So one panel will be 14.4m of 5cm x 5cm timber.
Which brings me to my second point - that will be pretty heavy, make sure you use an appropriate wall fixing.
blinddrew wrote: ↑Thu Oct 14, 2021 9:00 pm Ha! I think the only advice I can add is to work out how much wood you need, double check, double check again. Be prepared to be slightly mind-boggled at how much is actually required for a reasonably modestly sized diffuser.
According to this lumber weight calculator, 47.25 feet (14.4m) of 2x2 Scots Pine weighs just under 19Kg (42lb). Of course there are a number of variables with regards to how dry and what sort of wood it is (these can be plugged into the calculator linked above) but that seems a reasonable ballpark to me.
Posts: 7331 Joined: Wed Sep 01, 2004 12:00 am
Thanks guys for your input. Blind drew what calculator did you use to make yours or did you just go for random lengths. Thanks.
- Matthew Seed
Hi Matthew, I just went with a random approach. Given the long list of compromises that my studio is built on it seemed an acceptable trade off.
Mine are a bit smaller than the model in Hugh's link but basically I marked off the timber at increasing sizes (1 cm, 2cm, upwards), lobbed them all in a bag and pulled them out randomly to attach to the backboard.
About halfway down this page there are some photos: https://www.soundonsound.com/forum/view ... &start=270
