Cubase Ai: recording Instalooper plugin
I am trying out the Instalooper insert effects plugin on audio tracks in Cubase Ai 10.5 which enables loop effects to be applied. But I can't find a way to record the plugin's output on a new track. Can anyone suggest a method?
Re: Cubase Ai: recording Instalooper plugin
You should be able to select and render that track on its own. There should be an option to render into the current project, where it will be saved as another track. There may also be a render in place option, which may be quicker, but I don't have AI, so not sure exactly what options you have.
