Echo back to basics podcast.
Use this subforum to post your feedback and suggestions about the SOS Magazine, Apps, Replica edition, Website or SOS Forum.
Post by MOF »
I don’t think Paul White’s description of ADT is correct, he gives a short slapback delay as an example.
ADT can’t be done how he describes it because the record and playback heads can’t be close enough to each other.
ADT is achieved by feeding the synch head to another tape recorder that has an identical distance between the heads. Varispeed is used to thicken this sound as it’s mixed back with the original signal.
MOF
Posts: 2472 Joined: Thu Mar 06, 2003 12:00 am Location: United Kingdom
Re: Echo back to basics podcast.
Well, Paul's decription is what *we* called ADT back when I were a lad!
Posts: 21020 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
MOF wrote: Fri Oct 15, 2021 7:48 pmADT can’t be done how he describes it because the record and playback heads can’t be close enough to each other.
Depends on the tape speed, surely?
That approach would give a very short delay indeed, and I would think it more akin to chorusing than the 'ADT' I grew up with.
... but there are myriad ways of faking double tracking...
Posts: 42194 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Hmmm.
Has anyone seen a tape running at 30 IPS? I thought 15 was pretty scary :lol:
Posts: 19896 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Post by MOF »
https://www.waves.com/behind-abbey-road-adt-effect
If the delayed signal is exactly the same and then slowly varispeeded then it will be tape phasing, but a delay less than the slapback that Paul used will give the double track effect.
Typical head spacing at 30ips is still in slapback territory.
MOF
In the first proper studio recording that I did (at Airship Studio in Bognor) they had a Revox running at 15ips doing ADT. I did a varispeed modification to my Philips N4515 which allowed it to run faster than it was designed for to achieve the same thing.
Posts: 15876 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Folderol wrote: Fri Oct 15, 2021 8:54 pm Has anyone seen a tape running at 30 IPS? I thought 15 was pretty scary :lol:
I use 30ips fairly regularly here - it isn't so scary once you get used to it. The scariest tape related thing I find is rewinding 14" reels of 2" tape - the empty reel ends up running extremely fast at the end of the tape.
