Modular frustrations, wants, needs etc,
I’m continually surprised, at how many modules are produced, but few actually really fullfill my needs, it’s almost as if they always give with one hand, and take with the other.
Sometimes they get it right, but the market is still wide open for someone to come along with a few no compromise designs.
An LFO for instance, OK, it has to be voltage controlled, so many aren’t, it has to have a wide range, from minutes, to audio rate, it has to have a minimum of four "independent" outputs, and a wide range of waveforms, from sine to random, and it has to be reasonably priced, Batumi is a contender, but it’s still expensive.
Random modules? prime requirements, lots of VC inputs, of all parameters, cycle lengths from minutes to audio, multiple independent outputs.
Attenuators? should be automatically included on most modules,
I seem to have a lot of modules that aren’t voltage controllable, it’s frustrating, why would you "not want" an LFO to be VC? Oscillators with no modulation inputs? :-| random sources with no VC :crazy:
Behringer are in the position of being able to produce things really cheaply, if they focused on making new, innovative, feature packed modules of their own that addressed some of the things I mentioned instead of concentrating on reissues and copies, it would really be a breakthrough, and open up modular to those that regard it as too expensive.
Don’t copy limitations that have already been made, how about making new original modules that actually do more, and are more reasonably priced.
Posts: 19875 Joined: Sat Jul 12, 2003 12:00 am
Re: Modular frustrations, wants, needs etc,
Post by Ben Asaro »
What do you mean by "voltage-controlled" LFO?
Ben Asaro
Posts: 2907 Joined: Thu Feb 26, 2009 12:00 am Location: NYC
If you're talking about voltage control of LFO frequency that's going to be a tough one for stability - unless you have a number of steps to break up the range. Even the slightest drift would be instantly noticeable, far more than (say) a filter - unless the filter was resonant.
Posts: 19871 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Arpangel wrote: Mon Oct 18, 2021 9:32 am I’m continually surprised, at how many modules are produced, but few actually really fullfill my needs...
I think that's because your needs are extraordinarily comprehensive while your budget is minimal.
All the things you require are do-able, but it inherently costs a lot to include them all, and it's likely that the market demand for such a comprehensive device isn't large enough to justify its production.
The wider the oscillator's frequency range, the more complex the circuitry, the more expensive it will be. The more waveforms you want, the more expensive it will be to provide them. More outputs needed, the larger the panel needs to be and the more expensive it becomes.
The kind of flexibility you seek is just not basement budget territory, and it hardly seems fair to berate low-cost modules for not having all the bells and whistles.
And if voltage control is so important to you, it also doesn't seem justifiable to buy modules that aren't voltage controlled and then complain that they lack that feature!
Posts: 42179 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Hugh Robjohns wrote: Mon Oct 18, 2021 3:44 pm
I’m a big Doepfer fan, their modules are easy to understand, clearly laid out, they’ve stopped adding VC to some of their modules, the basic ones, the LFO used to have a VC version, the lack of VC on the Noise Random was always an issue, but it was cheap, easy to understand, but now, they’ve added VC, thumbs up for that.
There are a lot of good cheap modules coming out, by Dreadbox, Behringer, the Berry System 100 is their best so far IMO, sounds very good, lots of features, VC, but it was a good design in the first place.
The ARP stuff is a big disappointment, if I’d have known I wouldn’t have bought into it so much as I did.
The System 100 I was expecting to be my least favourite, has turned out to be the most useful.
Post by Ben Asaro »
I still don't understand what you want VC for in an LFO. What purpose does it serve? It sounds like you want options just to have options?
Ben Asaro
To be fair, I can see the practical usefulness of being able to vary the speed of vibrato, for example, using a CV generated by say, aftertouch. Or to control a pseudo rotary speaker effect's tremolo speed via an external CV.
Post by Ben Asaro »
Hugh Robjohns wrote: Tue Oct 19, 2021 1:19 pm To be fair, I can see the practical usefulness of being able to vary the speed of vibrato, for example, using a CV generated by say, aftertouch. Or to control a pseudo rotary speaker effect's tremolo speed via an external CV.
You can easily do with with an attenuator, though. And those can be voltage controlled.
Edit: In fact, I think Arp has Maths, no? You should be able to do virtually anything in that case!
Ben Asaro
Ben Asaro wrote: Tue Oct 19, 2021 1:22 pm
In my music I can think of a ton of reasons why VC of an LFO is essential, when creating feedback patches, feeding an LFO's speed input with a random wave, modulating itself, changing waveforms via CV, endless variations, and uses.
I patch an LFO into an oscillator to modulate pitch, I want to randomise the LFO, no VC? :(
Random modules in themselves, like the Doepfer 118, or Make Noise Wogglebug are fine if you want fast modulations, quite a bit of variation on the WB too, but I don’t, I want as slow as possible, and the only way I can do that is to patch an external slow LFO into the random, so I tend to use really slow LFO's with S+H modules, instead of random modules, and to get LFO's to run at the right speed sometimes needs an input from an external source, a very slow cycle, into the CV input.
Maths will go down to 25 mins per cycle, which isn’t bad, I’ve potentially got two LFO's there, great, but once you’ve used up Maths on those duties, you can’t really use it for anything else, one of the downsides of multi-function modules.
I want a couple of Sloths, but they are DIY, and I’m not, and they are rare secondhand.
Post by Aled Hughes »
The LFO on the Moog Mother 32 has VC control over the rate.
Maybe it could tick a box for you if you also need a few of the other things it has - sequencer, VCO, VCF, mixer, noise generator etc
Aled Hughes
Posts: 2028 Joined: Tue Oct 24, 2006 12:00 am Location: Pwllheli, Cymru
Aled Hughes wrote: Wed Oct 20, 2021 9:20 am The LFO on the Moog Mother 32 has VC control over the rate.
M32 is nice, but a bit OTT in this case, what I need to do is stop moaning, stop being so mean, and start buying a Batumi.
Post by nathanscribe »
Attenuating the LFO would only affect the depth, not the rate. VCLFO is a good thing, I enjoy a bit of envelope modulation of LFO rate for vibrato for example so it slows during release.
Arpangel: how about using a regular VCO but mixing a decent negative offset into the CV?
nathanscribe
Posts: 1542 Joined: Fri Jan 19, 2007 12:00 am Location: Wakefield, for my sins.
nathanscribe wrote: Wed Oct 20, 2021 10:58 am
Good thinking, that’s what’s great about modular, there’s always a load of workarounds, you just have to find them!
Yes, I could use a stackable and an attenuator to introduce a bit of random modulation from a sample and hold.
Post by Andy Cobley »
The thing that annoys me the most is a lot of modules only have a single input or output, meaning the needs for mults. Just my twopence but:
VFC modules should have more than one audio inputs to mix VCO ins
VCOs should have more than one F/oct again to mix control inputs
ADSRs should have more than one out so its easy to send it to a VCF and a VCA
etc.....
Andy Cobley
Posts: 123 Joined: Thu Sep 25, 2003 12:00 am Location: Fife, Scotland
Andy Cobley wrote: Wed Oct 20, 2021 6:55 pm The thing that annoys me the most is a lot of modules only have a single input or output, meaning the needs for mults. Just my twopence but:
etc.....
But surely that's missing the point of modular rather?! Mults are there for exactly some of these reasons and in addition to those modules that have limited numbers of outputs there are plenty that have more.
I'd rather buy a module with one output and mult it accordingly than have to pay a chunk more for the same module with two or more outputs, unless I'm actually looking for two or more outputs as a feature requirement in which case I'll go find one (or use mults if not)!
If you can't find a module with the outputs you need then there's always a workaround. The modular mindset isn't really about convenience it's about flexibility ;)
There weren't that many conveniences on this thing but it was an absolute joy playing with it (and it's what subsequently got me to take the plunge into modular in euro-rack form)!
Posts: 9593 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
As to the cost, it really doesn't add much. I design my own modules (for my own use) and the cost of an additional output is 1/4 opamp and a jack (about 40p). It's a bit more complicated for inputs, but only a few more resistors.
It does however add a bit more HP in some cases, which could be a problem for some.
Andy Cobley
Post by Ben Asaro »
I have to admit, I'm confused ... you have a want, which can be solved by using Maths. You own a Maths but don't want to use the Maths, because then you will have less Maths? :headbang:
Ben Asaro
Andy Cobley wrote: Wed Oct 20, 2021 7:55 pm It does however add a bit more HP in some cases, which could be a problem for some.
Would that need to be an open source design Andy?
Posts: 21652 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Ben Asaro wrote: Wed Oct 20, 2021 11:18 pm I have to admit, I'm confused ... you have a want, which can be solved by using Maths. You own a Maths but don't want to use the Maths, because then you will have less Maths? :headbang:
Hang on, of course, I use Maths, all the time, but that doesn’t stop me moaning about it, now, I’m having a different tack, I don’t look at Maths as a multi-function utility, no way, if you do that, you’re in for big trouble, because to get the most out of Maths you have to go deep into self patching, which wipes out utilities.
Maths is a stand alone complex oscillator, in every way, and that’s what I use it for now, I make sure I’ve got utility bases covered elsewhere, that’s why you may get confused about how I write about it.
I'm not sure what your asking Martin ? Most of my work is on github, but it's not really in a state others can reliably use.
Andy Cobley
Post by Ben Asaro »
Arpangel wrote: Thu Oct 21, 2021 8:58 am
Aaah … well, that explains it, kinda-sorta. In that case, all you need is a Disting! :D (kidding)
Ben Asaro
Martin Walker wrote: Wed Oct 20, 2021 11:30 pm
Oh dear, my subtle wordplay was obviously too subtle ;)
HP?
Open source?
Well I was pleased with it anyway :yawn:
Post by RichardT »
Martin Walker wrote: Thu Oct 21, 2021 8:28 pm
HP?
Open source?
I liked it
RichardT
Posts: 4981 Joined: Fri Aug 13, 2004 12:00 am Location: UK
Post by Random Guitarist »
Eddy Deegan wrote: Wed Oct 20, 2021 7:11 pm If you can't find a module with the outputs you need then there's always a workaround. The modular mindset isn't really about convenience it's about flexibility ;)
To me this is spot on, and is both the strength and weakness of a fully modular synth. I definitely struggle with keeping creative thoughts and modular synth engineering thoughts in my head at the same time.
Yes I can patch in a mult and configure things in a million ways, but by the time I've done that I have forgotten what I wanted to do musically. I think this is why I find semi-modulars like the Neutron and Mother32 hit such a sweet spot for me. I suspect if I were wealthy I'd end up with a lot of modules, and they'd end up semi permanently patched in groups for sounds I really liked.
At times I am in a love/hate relatuionship with modular, love the flexibility, but hate patching the thing. Perhaps I need to spend more time with the modular and develop a deeper ability to patch? Perhaps, for me at least, life is too short?
Random Guitarist
Posts: 1134 Joined: Tue Apr 01, 2008 12:00 am Location: West Sussex UK
