TS in TRS Output
TS in TRS Output
Post by dannyrhodes »
Hi All,
I have a patch panel that is connected to my audio interface.
The Audio interface has balanced TRS outputs that are connected to my patch panel, then the output from the patch panel connects to my speakers which at the moment have balanced inputs on the speakers, so all good.
However, I am getting some new speakers (iLoud Micro Monitors) and they have an RCA input only. Can I put a TS jack into the TRS output from the patch panel for my speakers? I've had a look online but can't seem to get an answer. Yes or no?!
Thanks in advance.
dannyrhodes
Posts: 3 Joined: Sun Jun 27, 2021 10:58 pm
Re: TS in TRS Output
What audio interface are you using?
Most will be fine with the cold output shorted to ground but there are one or two balanced outputs that wouldn't like it.
Posts: 15892 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
James Perrett wrote: Wed Oct 20, 2021 9:25 pm What audio interface are you using?
It's the UAD Apollo Solo USB. I've had a quick look at the manual and it say's this. 'The main outputs are line level. Connect the main outputs to the line level inputs of powered monitors or an amplifier+speaker system. Balanced TRS or unbalanced TS cables with ¼" plugs may be used.'
I know I could connect straight into the back of the interface, but i'd rather keep it connected via the patch panel.
dannyrhodes
Going via the patchbay should be exactly the same as using a single cable so you'll almost certainly be fine. Even if it does cause issues they will not damage anything, the most likely problem would be hum or noise but if the patchbay is in good order and correctly wired (TS or TRS) it should work fine.
Posts: 21959 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
dannyrhodes wrote: Wed Oct 20, 2021 9:30 pm It's the UAD Apollo Solo USB. I've had a quick look at the manual and it say's this. 'The main outputs are line level. Connect the main outputs to the line level inputs of powered monitors or an amplifier+speaker system. Balanced TRS or unbalanced TS cables with ¼" plugs may be used.'
You'll be fine using a TS cable from the patchbay.
Thanks for the quick replies. Really helpful :)
dannyrhodes
