New from www.amplesound.net
Here is our Super Rare Jedson LapSteel made with David Gilmour/Pink Floyd Specifications (EMG pickup). Want that MASSIVE ''Floyd Sound'' or Gilmour's Tone? Well, look no further because our Ample Slide LapSteel will deliver. Get ready to fly and make some music. By the way, ASL is certainly not only limited to Rock. It is designed for Psychedelic Rock, Ambient, Hawaiian, Blues and Country styles. More Information:https://www.amplesound.net/en/pro-pd.asp?id=39
https://youtu.be/hwTzMXf8qD8
https://soundcloud.com/ample-sound/asl-high-hopes
Don't break your bank account to get the real one at the Next Christies auction. Use our Virtual Instrument for a fraction of the price.
Available now with Intro Price: $89 until November 21st (Reg. $119). There is a further 10% off for loyal users.PURCHASE HERE:https://www.amplesound.net/en/purchase.asp (loyal users, login to your account before purchase)
Ample Slide Lapsteel - Demo & Review + GIVEAWAY !!!!!!!!!!!!!!
https://youtu.be/sJ6CMSLoJMA
Sampling:
-Size: 2.8 GB.
-Stereo and Mono Modes.
-Sustain, Legato Slide, Slide in & out, Quarter Slide, Natural Harmonic, Legato Vibrato, Buzzing, Glissando 9 articulations.
System Requirements:
-Windows: Windows 7/8/10, 64-bit only (32-bit not supported).
-Mac: 10.9 or higher.
-VST2, VST3, AU, AAX and Standalone host.
-10 GB Hard Disk, Intel i5 or higher.
AMP Simulator:
-Built-in AMP system, including 6 classic AMP models: Metal Double (modeled on Mesa Boogie Dual), Metal Treble (modeled on Mesa Boogie Triple), Lead 800 (modeled on Marshall JCM800), Jazz 120 (modeled on Roland JC120), 65 Twang (modeled on Fender 65 Twin Reverb) and 57 Delight (modeled on Fender 57 Deluxe).
-7 matching cabinets:1x12 57D, 2x12 65T, 2x12 120, 4x12 60A, 4x12 60B, 4x12 Ro and 4x12 Ri.
-Each Cabinet has 8 mic options: U87, C414, MD421, SM57, E609, C414 XLS, R121 and M160.
Riffer:
-Supports 64 measure riff, new Legato Position property to control the start time of a Legato.
-String Roll Editor: can clearly show fingering, articulation, expression and even playing noise. Every note has 8 attributes - pitch, velocity, length, off velocity, articulation, legato, vibrato and bend, with which you can make a delicate lick.
-Multiple selection and operation, undo and redo etc. multiple MIDI tools, including fixed velocity, length legato and restrict, select, move, draw, erase, split, glue etc.
FX:
-High order 8-band EQ, intuitive control of frequency response, real-time visualization of input and output spectrum, support of soloing single band..
-2-Line Compressor, real-time visualization of input and output signal, two detection modes RMS & Peak, support of soft knee, auto release and auto makeup.
-6-Tap Echo, real-time visualization of the processing of stereo signal, can tweak the parameters of 6 echo points individually: feedback, pan, volume etc.
-IR Reverb, providing four types of IR: Room, Studio, Hall, and Larger Hall. 3D visualization of IR spectrum.
https://youtu.be/Zi4MIOsleBQ
https://soundcloud.com/ample-sound/asl-aloha-oe
HAVE A GREAT DAY!!!!!!!!!!!!
