2n5457
2n5457
JFETs, had to buy a pack of ten to get one so if anyone is in real need give me a PM and I will pop one in an envelope for them.
Posts: 18096 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Re: 2n5457
Don't have a need for one, but out of curiosity looked up their spec. Not bad, but quite high gate leakage by today's standards.
Posts: 19868 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Re: 2n5457
Folderol wrote: Sat Oct 30, 2021 7:42 pm Don't have a need for one, but out of curiosity looked up their spec. Not bad, but quite high gate leakage by today's standards.
Well, if you are going to be picky Will. NO free FETs for you!
Heh, I just need to knock up a very basic guitar pre amp for a little project I am working on as a present for my daughter's partner on his birthday.
Re: 2n5457
I think the last time I soldered in a FET it was a 2N3819 (does that date me?)
Posts: 21631 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Re: 2n5457
WOW ! this is spooky, I recently replaced some J112's in an Alesis Microns power_on_click_silencer / general_output_knackerer circuit.
Maybe there's a FET virus......
Posts: 4538 Joined: Sun Aug 12, 2018 2:40 pm Location: British Isles
Re: 2n5457
Martin Walker wrote: Sat Oct 30, 2021 9:17 pm I think the last time I soldered in a FET it was a 2N3819 (does that date me?)
Yes :lol:
Oh, and I left the one in my signal generator severely alone (if it ain't broke, don't fix it).
Re: 2n5457
Yes! I used a pair in a cascode band ll pre amp before we got the Boughton Green Road repeater.
Re: 2n5457
I'm definitely old then ;)
Re: 2n5457
Just FYI chaps. I built the pre amp, circuit called for a 6k8 drain load and a 2k2 source 'bias' resistor. The FET did not pull nearly enough current from a 12V supply (Vdrn too high) I had to reduce the source R to 270 Ohms to get Vdrn near 1/2 supply.
Hooked into the gadget I built it for however, on a 23V supply it gave plenty of clean gain and low noise when tested with a Strat clone.
Re: 2n5457
Good to see you got it working. Bias voltage on older FETs was always a guessing game. It's rather given away by the cut-off voltage spread. I just looked it up for that one and for fairchild (one of the good guys) it's -0.5 to -6!
Re: 2n5457
Post by ajay_m »
The process by which jfets are made intrinsically results in much higher parameter spreads than for bipolar transistors. Consequently it is sometimes necessary to test several devices to find e.g a reasonably matched pair. There's a good discussion of this in "the art of electronics", a book well worth acquiring if you're seriously interested in circuit design.
ajay_m
Posts: 1286 Joined: Mon Jan 16, 2017 7:08 pm
Re: 2n5457
Post by tubegeek »
Beware of counterfeit FETs, especially through-hole parts common for audio, guitar pedals etc. They are rife. Ebay & Amazon are very hit-or-miss in terms of authentic items.
If they are too cheap to be true, they are too cheap to be genuine, in my experience.
tubegeek
Posts: 2 Joined: Wed Oct 31, 2018 2:58 pm
