Sit stand desk - monitors on floor stands, or on [stands on] the desk?
Re: Sit stand desk - monitors on floor stands, or on [stands on] the desk?
Can you do anything at the wall/ceiling corners?
I think I'm pretty maxed out in terms of what will practically/sensible fit in the space, though I'm working on seeing if I can get bigger tri-corner traps at the top of the back wall; I can also in-fill (back fill) some of the front floor to ceiling corners traps more with rockwool.
It's certainly sounding significantly better than it did in the previous room, which had exactly the same treatment, and was basically the same size (though had a 40cm lower ceiling). I think the main difference is that I'm able to position panels much more optimally here, though I'm sure the extra ceiling height, non-parallel side wall and less solid walls are helping too (the previous place was a loft conversion, but professionally soundproofed).
Will be interesting to see how it measures in REW ...
