Best USB Keyboard with MIDI sockets?
I am looking for a USB Keyboard that also has MIDI sockets to drive external MIDI gear (sampler).
I did think about a cheap USB to MIDI in/out cable (which I could still do) but then thought of turning to a USB keyboard with MIDI as a step up?
I have done a quick search and saw that most are now just USB based, but the Arturia KeyStep is one with both MIDI and USB for hardware and software.
Are there any other good recommendations to marry software and drive older hardware?
Thank you!
Thank you!
Re: Best USB Keyboard with MIDI sockets?
AFAIK a USB to MIDI I/O cable will not work with a USB controller keyboard, only with a computer or standalone USB host of some kind (Kenton used to do something of the kind).
Jedi Poster - Posts: 19770 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Sam Spoons wrote: ↑Fri Nov 26, 2021 2:26 pm AFAIK a USB to MIDI I/O cable will not work with a USB controller keyboard, only with a computer or standalone USB host of some kind (Kenton used to do something of the kind).
Yes sorry i should have explained, I could just get a USB to MIDI I/O cable as a simple I/O interface, 'or' move up a little to a keyboard, with built in MIDI (as well as a USB controller) so its all in one
james090 wrote: ↑Fri Nov 26, 2021 2:28 pmSam Spoons wrote: ↑Fri Nov 26, 2021 2:26 pm AFAIK a USB to MIDI I/O cable will not work with a USB controller keyboard, only with a computer or standalone USB host of some kind (Kenton used to do something of the kind).
I assumed you had wanted to connect the keyboard directly to the midi device. FWIW I had a Keystep briefly, I'm no keyboard player but have always hated mini keys. I thought it worth one more try as a portable rig but it wasn't to be so it went back. In every other way the Keystep was a great little keyboard with some excellent features but I just couldn't get on with the keys...
https://www.gear4music.com/Recording-an ... VQQAvD_BwE
Don't know about "best" James but that is only 80 quid. Controller kbds with a MIDI port* are getting very rare it seems? Looking at M-Audio, Roland and Akai fairly quickly found none. In fact there seems to be a 'generic' rear panel layout that most companies use and then 'badge' the box!
I have an Evolution Ekeys 49 controller I bought years ago and that does have a DIN out as well as USB but the latest Evolution products (looking JUST like M-Audio, di da) have dropped the 5 pin port.
*You are unlikely to find a MIDI 'IN' on a controller because they have no 'sounds' of their own to trigger. But then I know little about MIDI and keys!
james090 wrote: ↑Fri Nov 26, 2021 2:19 pm I am looking for a USB Keyboard that also has MIDI sockets to drive external MIDI gear (sampler).
Thank you!
One of these maybe? M Audio Oxygen 61 USB MIDI? And I think the M-Audio Keystation series are highly regarding keyboards
Is it about a bicycle?
Hi Andy (always one isn't there!) it seems the Keylab 49 is a MIDI to USB interface as well as a keyboard? It is also described as a "synthersizer" so maybe it has internal oscillators?
Some keyboards are full blown audio interfaces as well, the lines are a bit blurred. I was just giving the OP a bit of caveat whatsit!
My NI Komplete Kontrol S61 Mk2 has MIDI in and out sockets. Great keyboard, but most of the advanced functionality (scales, arp, chords) is reserved for NKS instruments.
- PeterRees11
New here - Posts: 10 Joined: Sun Nov 20, 2016 11:00 pm
Yep, the key here (see what I did?) is that these controllers have USB interfaces that you can plug into a computer, and so it's useful for them to offer an additional MIDI input so that you can plug another keyboard into them and get both the controller MIDI data and that external MIDI data into your computer.
I've got 5-pin DIN MIDI In, Out and Thru sockets on my Novation 25SL MkII controller for this purpose.
Posts: 20657 Joined: Wed Jan 13, 2010 8:44 am
You might want to look into one of these devices. It will give you midi I/O from any USB keyboard.
https://www.thomann.de/gb/kenton_midi_u ... 9&reload=1
- Humble Bee
Regular - Posts: 395 Joined: Mon Jan 08, 2007 12:00 am Location: Cloughton Newlands
- Yearofthegoat
Poster - Posts: 47 Joined: Mon Feb 01, 2021 1:23 pm
Yearofthegoat wrote: ↑Thu Dec 02, 2021 2:17 am It's okay keys-wise but not the best. But then it didn't cost very much.
To be honest I think that's true of pretty much all MIDI controllers to some degree. Even the expensive NI ones!
I thought this was me imagining this, and that I was remembering DX7 and D50 playability through rose coloured glasses, so I was surprised to find a couple of years ago a friend had got his D50 out of storage for a project, and he let me have a little play one night. And Good grief! Yes it was as lovely to play as I remember. My Novation feels like a toy in comparison (has to be said that my much more modern Roland keyboards don't cover themselves in glory in this regard either!). The nicest action synth I own now is the Moog Sub 37.
