I have a Behringer XM8500 mic and a cheap M-Audio M-Track Solo, audio interface. My mic is currently sitting on my table I am planning to use a mic arm and a popfilter+ shockmount.
All my friends say that my mic sounds terrible even when I have the mic close to my mouth. I am using it with discord only right now.
Are there any fixes or something I can do? If not what should i buy to get better sound?
Bad sounding microphone
Re: Bad sounding microphone
It would be best to record a sample, put it up on SoundCloud, and post a link so we can hear what's going on. Terrible sound can mean many things.
- resistorman
Frequent Poster - Posts: 2697 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
The XM8500 needs the treble boosting by 6dB or so and the bass reducing by a similar amount and then it can sound very similar to an SM58 when used close-up. But it isn't a very balanced sounding microphone without using EQ.
It's not a mic designed to be used with a pop filter. It's a hand-held stage mic. To get a pop filter to work, the filter needs to be several inches away from the mic and several inches away from the mouth, by which time you've got a very low level signal and you've lost the bass boost from the proximity effect.
What do you actually want to do with the mic? Record, or podcast?
