Spec required to run Logic?
Hi everyone,
My iMac has the following spec: 1.4 GHz Dual-Core Intel Core i5 processor, 8 GB 1600 MHz DDR3 RAM and Intel HD Graphics 5000 1536 MB.
Is this enough to run Logic Pro X?
Thank you, Paul
Thank you, Paul
- The Paul meister
Regular - Posts: 295 Joined: Tue Feb 28, 2006 12:00 am
Re: Spec required to run Logic?
What OS are you running on that? If you’re purchasing Logic it runs on OS 11 or later. Check out this. https://www.apple.com/uk/logic-pro/specs/
If you’ve previously purchased it and want to put it on that machine that’s a different and more complicated question!
Hi IAA,
Thanks for your reply. Yes I am running Mac OS 11. I haven't bought Logic yet - I'm thinking about buying it. I had already seen the page that you suggested, but on there it doesn't actually say what computer you need to run Logic. That's why I made the original post.
Can you or anyone else advise on whether my computer will run Logic?
Thanks, Paul
Thanks, Paul
- The Paul meister
The Paul meister wrote: ↑Sat Dec 04, 2021 7:54 pm it doesn't actually say what computer you need to run Logic. That's why I made the original post.
I think the implication is if your computer can run OS11, it'll run the latest Logic Pro.
Hi Kwackman,
Thanks for your reply,
Paul
Paul
- The Paul meister
Ok, thanks.
What does YMMV mean?
Paul
Paul
- The Paul meister
Ok, cheers
- The Paul meister
The Paul meister wrote: ↑Sat Dec 04, 2021 6:12 pm Hi everyone,
Thank you, Paul
Hi there Paul I have a dual core i5 macbook and I run Logic Pro X on Sierra 10.12
I'm using samples, also soft synths supplied with Logic Pro X. Sometimes it can't cope with more than 8 tracks of Logic soft synths.
System Overload message.
If I was doing only audio recordings and minimal processing of audio then my i5 macbook would coped better.
- tea for two
Frequent Poster - Posts: 3436 Joined: Sun Mar 24, 2002 12:00 am
Ok, thanks for your reply.
Paul
Paul
- The Paul meister
Hi Kwackman,
I went on the app store like you suggested and it said 'it works on this mac'.
Thanks for your advice,
Paul
Paul
- The Paul meister
Welcome.
The issue is as I mentioned, it will work, but it may get System Overload message, then freeze, as with my i5 macbook, depending on what's being done in Logic X.
If funds would stretch I would recommend a 2020 M1 Mac Mini approx £750.
It is something else with Logic X way more than intel i7 i9 mac.
Else i7 mac with Highest GHz to cope with soft synths, audio processing,
and SSD drive for recording audio onto and for loading samples.
The Paul meister wrote: ↑Sun Dec 05, 2021 10:58 am I went on the app store like you suggested and it said 'it works on this mac'.
- tea for two
Hi everyone,
Thanks for your replies. I have downloaded the 90 day free trial of Logic and it's working fine. I don't know how many soft synths I can run at the same time - I haven't tried that yet.
Cheers, Paul
Cheers, Paul
- The Paul meister
I run a late 2013 MacBook pro, quad core i7s, 8GB RAM on Big Sur. Logic runs ok... to a point. Logic's drum producer tracks (if I need more than one), certain virtual instruments (a couple I love from SpitFire in particular) cause it to be a bit challenging. Of course there are workarounds that work pretty well. You can freeze tracks so they take up less CPU, you can go into low latency mode when you record, and constantly be playing with your buffer size. While very doable you may get some frustration in certain situations.
If your projects start pretty basic and you don't mind the easy to use tools logic provides to help it run smooth, you'll be fine.
blake
blake
- blakedirksen
Poster -
Posts: 68 Joined: Fri Aug 07, 2020 8:29 pm
Hi Blake,
Thanks for the info.
Cheers, Paul
Cheers, Paul
- The Paul meister
The Paul meister wrote: ↑Sun Dec 05, 2021 1:20 pmI have downloaded the 90 day free trial of Logic and it's working fine.
Good stuff!
It might be worth looking at adding some extra RAM to your mac, if it's not too expensive.
Hope it works out for you.
Thanks Kwackman,
Paul
Paul
- The Paul meister
