I’m regularly getting waveforms in Reaper that are constantly one sided, like I only see the lower part of a waveform, with little above that.
Is this something to do with DC offset issues? I seem to remember reading about this somewhere, but can’t remember.
One sided waveforms?
Re: One sided waveforms?
Music? Voice? If music which instrument(s)?
An image/screenshot would be useful...
Assymetric waveforms are not at all uncommon and usually nothing to do with DCO... there are regular discussions here - including just last week iirc.
- Mike Stranks
Jedi Poster - Posts: 9174 Joined: Fri Jan 03, 2003 12:00 am
Mike Stranks wrote: ↑Sun Dec 05, 2021 8:57 am Music? Voice? If music which instrument(s)?
Anything, any sound, sometimes the waveform is entirely in the positive, or negative.
I’m wondering if there’s some sort of phase cancellation going on, somewhere in the signal chain?
That’s another thing
There are lots of perfectly natural reasons why this can occur, and it's usually to do with the harmonic composition (and the phase relationships of those harmonics) within the signal.
Asymmetry is very common with voices, brass and simple synthesizer sounds, for example.
https://www.soundonsound.com/sound-advi ... lop-sided
DC offset issues are extremely rare and the kind of fault condition today that could cause them would be evident in other, more obvious ways.
But if it was a DC offset you would see a decaying waveform settling away from the centre line, whereas an asymmetrical waveform will settle on the line.
My advice, stop looking at the pretty pictures and concentrate more on the lovely sounds....
Posts: 33817 Joined: Fri Jul 25, 2003 12:00 am
Vivre la difference!
I agree with Hugh. 'Pictures' can be off putting and in any case the 'waveforms' you get in DAWs are not 'true' in the sense of that which an 'scope would display (and that would be different for various timebase and trigger/delay settings)
Sound 'pictures' have a place in the home studio but mainly as a diagnostic tool. When son was here making music he would 'experiment' with various gear lashups. Once a week or so I would run a Right Mark Anny test and almost always pickup hums above my -93dBFS baseline noise floor. Some re dressing of mains and audio cables usually restored quietitude.
It's almost like physics or something.
There is a difference between a sound engineer and a recording technician. One knows which buttons to press. The other knows what happens when the buttons are pressed!
Hugh Robjohns wrote: ↑Sun Dec 05, 2021 1:09 pm
Think about how the accordion makes its sound, and how that might be conveyed in sound pressure variations....
You have got a point there Hugh, my friend explained to me, his accordion has three reeds, which you can switch in and out, that produce different chorusing effects, which may have something to do with it.
