One sided waveforms?
I’m regularly getting waveforms in Reaper that are constantly one sided, like I only see the lower part of a waveform, with little above that.
Is this something to do with DC offset issues? I seem to remember reading about this somewhere, but can’t remember.
Posts: 19901 Joined: Sat Jul 12, 2003 12:00 am
Re: One sided waveforms?
Post by Mike Stranks »
Music? Voice? If music which instrument(s)?
An image/screenshot would be useful...
Assymetric waveforms are not at all uncommon and usually nothing to do with DCO... there are regular discussions here - including just last week iirc.
Posts: 10585 Joined: Fri Jan 03, 2003 12:00 am
Mike Stranks wrote: Sun Dec 05, 2021 8:57 am Music? Voice? If music which instrument(s)?
Anything, any sound, sometimes the waveform is entirely in the positive, or negative.
I’m wondering if there’s some sort of phase cancellation going on, somewhere in the signal chain?
MoooHASSIVE even harmonic distortion Tone!
Posts: 18119 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Arpangel wrote: Sun Dec 05, 2021 8:27 amI’m regularly getting waveforms in Reaper that are constantly one sided, like I only see the lower part of a waveform, with little above that.
There are lots of perfectly natural reasons why this can occur, and it's usually to do with the harmonic composition (and the phase relationships of those harmonics) within the signal.
Asymmetry is very common with voices, brass and simple synthesizer sounds, for example.
https://www.soundonsound.com/sound-advi ... lop-sided
DC offset issues are extremely rare and the kind of fault condition today that could cause them would be evident in other, more obvious ways.
But if it was a DC offset you would see a decaying waveform settling away from the centre line, whereas an asymmetrical waveform will settle on the line.
My advice, stop looking at the pretty pictures and concentrate more on the lovely sounds....
Posts: 42207 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Arpangel wrote: Sun Dec 05, 2021 9:28 amI’m wondering if there’s some sort of phase cancellation going on, somewhere in the signal chain?
Some sort of weird phase cancellation that only removes negative half cycles? That's clever! :think::geek:
Thanks folks, it’s mainly on accordion, if that helps?
:think:
Arpangel wrote: Sun Dec 05, 2021 12:46 pm Thanks folks, it’s mainly on accordion, if that helps?
:think:
Vivre la difference!
I agree with Hugh. 'Pictures' can be off putting and in any case the 'waveforms' you get in DAWs are not 'true' in the sense of that which an 'scope would display (and that would be different for various timebase and trigger/delay settings)
Sound 'pictures' have a place in the home studio but mainly as a diagnostic tool. When son was here making music he would 'experiment' with various gear lashups. Once a week or so I would run a Right Mark Anny test and almost always pickup hums above my -93dBFS baseline noise floor. Some re dressing of mains and audio cables usually restored quietitude.
Think about how the accordion makes its sound, and how that might be conveyed in sound pressure variations....
It's almost like physics or something.
Posts: 28086 Joined: Sun Jul 05, 2015 12:00 am Location: York
:ugeek::shh:
There is a difference between a sound engineer and a recording technician. One knows which buttons to press. The other knows what happens when the buttons are pressed! :lol:
Hugh Robjohns wrote: Sun Dec 05, 2021 1:09 pm
You have got a point there Hugh, my friend explained to me, his accordion has three reeds, which you can switch in and out, that produce different chorusing effects, which may have something to do with it.
No, it doesn't. :think:
Post by MOF »
No one told me anything about pressing buttons. :lol:
MOF
Posts: 2474 Joined: Thu Mar 06, 2003 12:00 am Location: United Kingdom
Post by shufflebeat »
Arpangel wrote: Sun Dec 05, 2021 8:04 pm
You have got a point there Hugh, my friend explained to me, his accordion has three reeds, which you can switch and out, that produce different chorusing effects, which may have something to do with it.
Possible idiot question here but they are my specialty:
Taking this from the "moving air = moving diaphragm" end of the process, are we suggesting that the diaphragm gets pushed away from the resting position and doesn't recover properly to zero?
MOF wrote: Sun Dec 05, 2021 8:29 pm
Hugh Robjohns wrote: Sun Dec 05, 2021 8:09 pm There is a difference between a sound engineer and a recording technician. One knows which buttons to press. The other knows what happens when the buttons are pressed! :lol:
i thought that was the difference between an accordion player and an accordion maker.
shufflebeat
Posts: 9730 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
Certainly not an idiot question, and one that comes up often.
shufflebeat wrote: Sun Dec 05, 2021 8:31 pmTaking this from the "moving air = moving diaphragm" end of the process, are we suggesting that the diaphragm gets pushed away from the resting position and doesn't recover properly to zero?
No, that would be the acoustic equivalent of a DC offset.
If you think of a plucked acoustic guitar string, or a violin, the string vibrations are equal back and forth, so the compressions and rarefactions in the air pressure are balanced. So the waveform captured by a microphone is more or less symmetrical (harmonic phases permitting)
But in air-blown instruments -- voices, brass, accordions etc, the noise generation requires constant positive air pressure so the vibrating reed (etc) will inevitably create stronger compressions (because they are 'power-assisted') than rarefactions (which have to fight against the causation pressure), hence an asymmetrical waveform is produced.
But when the wind stops blowing the vibrating sound enerator decreases and the waveform decays to normal ambient pressure.
Hugh Robjohns wrote: Sun Dec 05, 2021 8:59 pm
Got it. So if I'm understanding correctly that's a similar situation to that which I was describing but happening at the instrument reed rather than the mic diaphragm. Is that what you're suggesting?
shufflebeat
shufflebeat wrote: Sun Dec 05, 2021 10:07 pm So if I'm understanding correctly that's a similar situation to that which I was describing but happening at the instrument reed rather than the mic diaphragm. Is that what you're suggesting?
Yes, I guess so.
Hugh Robjohns wrote: Sun Dec 05, 2021 10:57 pm
Yes, I guess so.
It sometimes seems like numbers and diagrams exist in their own separate reality, particularly when they are describing movement of electrons.
For the relatively innumerate like myself it's reassuring to have a good old imaginary model of wood, metal and air that corresponds clearly with the numbers that represent it.
Much appreciated.
shufflebeat
I was just curious, it sounds good, so that’s OK.
