Hi people,
I need some help figuring out why my Radial J48 has such a loud noise floor compared to the Hi-Z input of my Apollo. I don't know much about electricity stuff, so explain stuff to me like I'm the moron that I am lol.
I made a small test, where I recorded the noise I get, first half of the audio file is with the Volume Knob on my Ibanez RGR-5221 at 0%, and then I turn it up to 100%. Pickup used is a passive Bareknuckle Brute Force Humbucker in Bridge position with Tone all the way to 100%. Link to the files down below.
Signal Chain as follows:
Radial_J48: Guitar -> J48 (only 15dB PAD engaged) -> UAD Apollo Twin X (20dB Gain (10db is minimum) +48V) -> Neural DSP Fortin Cali Plugin (High Gain)
Apollo Hi-Z: Guitar -> Hi-Z input (15dB Gain (10db is minimum)) -> same Fortin Cali plugin
Gain Staging was done so that I would only clip when playing really, really hard
I tested both inputs of my Apollo with the J48, results are the same for both. And now I gotta ask a stupid question: Isn't the J48 supposed to be quieter than a built-in Hi-Z input? What produces that kind of noise and is it normal? And if not, what can I do to fix it?
Link to .wav files: https://drive.google.com/drive/folders/ ... sp=sharing
Cables used:
https://www.thomann.de/de/cordial_cci_3 ... ns_67303_2
https://www.thomann.de/de/cordial_ctm_15_fm_bk.htm
Radial J48 more noise than Hi-Z Input?
Re: Radial J48 more noise than Hi-Z Input?
I'm not in a position to listen critically to your clips today, but I'll check them tomorrow.
The j48 and built-in DI should be similarly low-noise and I wouldn't expect one to be significantly noisier or quieter.
As for the J48, make sure you don't have 'merge' or the ground-lift option selected. Also ensure the J48 isn't placed on or near other electronic equipment which might cause interference.
It's worth trying the high-pass filter as that might help, and im wondering why you need the 15dB pad as that will inherently degrade the noise performance
Posts: 33792 Joined: Fri Jul 25, 2003 12:00 am
Why do you have the 15 db pad engaged on the DI with a passive pickup? That may be the whole problem.
- resistorman
Frequent Poster - Posts: 1801 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
Just buy the Hydrasynth already
As I understand it, the max input levels are +10dBu for the J48 and +12.2dBu for the Apollo Twin X, so very similar and if the OP was clipping the J48 Id have expected the Apollo to clip too.
So I don't understand why the pad is being employed on the J48 and ss said above, that choice could well explain the difference in noise performance.
Thank you guys for your responses! The Bareknuckle Brute Force Pickup is a High Output pickup. It will clip easily if the 15 PAD is not engaged.
I also measured the noise floor: -34.6 for the J48 and -54.9 for the Hi-Z input (put through the Amp Sim plugin at high gain, of course!).
Gain difference should be 0.5dB at max, since it was gain staged with 0.5dB intervals, so that I would just clip with my hardest playing.
If I disable the PAD, the noise floor goes from -34.6dB to -36.7 dB, which is still significantly higher.
I'm struggling to believe the J48 clips but the Apollo DI doesn't.
Are you sure its not the apollo mic input that's clipping?
Hugh Robjohns wrote: ↑Sun Dec 05, 2021 10:55 pm I'm struggling to believe the J48 clips but the Apollo DI doesn't.
Well yeah, when the 15dB PAD on the J48 is NOT engaged, then the Apollo Mic input clips very easy. How can I see if the J48 clips or not? Sorry if this is a stupid question.
A guitar pickup is not going to clip the Radial. You likely need to pad the mic input.
- resistorman
The Twin manual states that the preamp has a 20db pad. Try not padding the Radial and use the Twin pad instead.
- resistorman
resistorman wrote: ↑Mon Dec 06, 2021 1:29 am The Twin manual states that the preamp has a 20db pad. Try not padding the Radial and use the Twin pad instead.
This reduces the noise floor and changed the tone a tiny bit, but I'm not sure yet if I find it better or worse.
I know from the Periphery 3 and 4 documentaries that they recorded guitar as well as bass DI with the J48 (guitars into Focusrite Pre8X and bass into the Apogee Symphony, I think) and both have the 15dB Pad engaged.
Now, their productions seem really top notch, but why would they record their DI's with so much noise if it wasn't somehow avoidable? This is what confuses me.
Hard to say. The signal coming from a passive pickup is already tiny and attenuating it makes no technical sense. Possibly they have very hot active circuitry in their instruments. Or maybe settings had changed by the time they filmed it. Or maybe they saw someone else doing it and thought that is the way it's done, the noise didn't bother them, and they just got on with making music.
- resistorman
BTW, what are you trying to accomplish by using the Radial?
- resistorman
