Hi again everyone,
I have some soft synths from Native Instruments and IK multimedia ready to download from the Native Access and IK Product Manager respectively. When I try to install from IK it only gives me the option to install onto my hard disk which is called 'Untitled'. I have installed Sampletank 4 on the hd but I don't seem to be able to access it in Logic. I've also tried installing a soft synth from Native Access, but again I can't access it in Logic.
Can anyone help?
Thanks a lot, Paul
Installing soft synths in Logic
- The Paul meister
Regular - Posts: 64 Joined: Tue Feb 28, 2006 12:00 am
Re: Installing soft synths in Logic
I’m a bit confused when you say ‘ready to download’ have you downloaded them yet, I presume you have from what you say later, have you validated the licences?
In the early days NI instruments had to be run in ‘stand alone’ mode first i.e. double click the App’ in the Applications folder, not sure if that’s still necessary, also have you quit Logic first to allow it to discover and validate the new plugins?
There are several pages in NI Access, check them all to see if you’ve validated plugins and that there are no missing links i.e. the Repair button.
Have you checked Logic’s plugin manager?
Or go to "/Library/Audio/Plug-Ins/Components" and see if it’s there. If not, find it and put it there.
- in.name.only
Poster - Posts: 38 Joined: Sat Jan 23, 2021 5:48 am
Hi MOF,
No, I haven't installed all the software yet as I'm trying to find the right place to put it before downloading it. Yes I did quit Logic to let it discover the plug ins but that didn't work either. Thanks for your reply, but I think I'll have to contact Logic help.
Cheers, Paul
Cheers, Paul
- The Paul meister
Hi in.name.only,
I don't seem to be able to find Logic's plug in manager. Also I can't find the Components folder that you suggested. Is this anything to do with the fact that I'm running Logic in trial mode, i.e. I haven't paid for it yet?
Cheers, Paul
Cheers, Paul
- The Paul meister
Download it and run the installers, they will create the necessary folders in the correct file structure if they don’t already exist.
Hi MOF,
I have installed Sampletank 4 from IK Multimedia, but it only installs as the standalone version on the hard disk. It doesn't seem to create the file structure as you suggested.
Cheers, Paul
Cheers, Paul
- The Paul meister
The Paul meister wrote: ↑Thu Dec 09, 2021 12:00 pm Hi in.name.only,
Cheers, Paul
Lets see if the Audio Units are installed, open a terminal and type:
auval -a
This will give you a list of all the audio units installed, cut and paste the list here.
Cheers
Andy
Signature block of the week.
Hi Andy,
It's quite a long list. It does include Sampletank. Here's the result from the Terminal:
Cheers, Paul
Last login: Thu Dec 9 14:23:57 on ttys000
test@tests-iMac ProfileData_20211209_115534 % auval -a
AU Validation Tool
Version: 1.8.0
Copyright 2003-2019, Apple Inc. All Rights Reserved.
Specify -h (-help) for command options
aufx bpas appl - Apple: AUBandpass
aufx dcmp appl - Apple: AUDynamicsProcessor
aufx dely appl - Apple: AUDelay
aufx dist appl - Apple: AUDistortion
aufx filt appl - Apple: AUFilter
aufx greq appl - Apple: AUGraphicEQ
aufx hpas appl - Apple: AUHipass
aufx hshf appl - Apple: AUHighShelfFilter
aufx lmtr appl - Apple: AUPeakLimiter
aufx lpas appl - Apple: AULowpass
aufx lshf appl - Apple: AULowShelfFilter
aufx mcmp appl - Apple: AUMultibandCompressor
aufx mrev appl - Apple: AUMatrixReverb
aufx nbeq appl - Apple: AUNBandEQ
aufx nsnd appl - Apple: AUNetSend
aufx nutp appl - Apple: AUNewPitch
aufx pmeq appl - Apple: AUParametricEQ
aufx raac appl - Apple: AURoundTripAAC
aufx rogr appl - Apple: AURogerBeep
aufx rvb2 appl - Apple: AUReverb2
aufx sdly appl - Apple: AUSampleDelay
aufx tmpt appl - Apple: AUPitch
aupn ambi appl - Apple: AUSoundFieldPanner
aupn hrtf appl - Apple: HRTFPanner
aupn sphr appl - Apple: AUSphericalHeadPanner
aupn vbas appl - Apple: AUVectorPanner
aumu Stk4 Ikmm - IK Multimedia: SampleTank 4
aumu dls appl - Apple: DLSMusicDevice
aumu msyn appl - Apple: AUMIDISynth
aumu samp appl - Apple: AUSampler
aumx 3dem appl - Apple: AUSpatialMixer
aumx 3dmx appl - Apple: AUMixer3D
aumx mcmx appl - Apple: AUMultiChannelMixer
aumx mspl appl - Apple: AUMultiSplitter
aumx mxmx appl - Apple: AUMatrixMixer
aumx smxr appl - Apple: AUMixer
aufc conv appl - Apple: AUConverter
aufc defr appl - Apple: AUDeferredRenderer
aufc ipto appl - Apple: AUNotQuiteSoSimpleTime
aufc merg appl - Apple: AUMerger
aufc nutp appl - Apple: AUNewTimePitch
aufc splt appl - Apple: AUSplitter
aufc tmpt appl - Apple: AUTimePitch
aufc vari appl - Apple: AUVarispeed
auou ahal appl - Apple: AudioDeviceOutput
auou def appl - Apple: DefaultOutputUnit
auou genr appl - Apple: GenericOutput
auou rioc appl - Apple: AUAudioIO
auou sys appl - Apple: SystemOutputUnit
auou vpio appl - Apple: AUVoiceProcessor
augn afpl appl - Apple: AUAudioFilePlayer
augn nrcv appl - Apple: AUNetReceive
augn sspl appl - Apple: AUScheduledSoundPlayer
augn ttsp appl - Apple: AUSpeechSynthesis
auol tmpt appl - Apple: AUTimePitch
auol vari appl - Apple: AUVarispeed
Cheers, Paul
AU Validation Tool
Version: 1.8.0
- The Paul meister
The Paul meister wrote: ↑Thu Dec 09, 2021 2:29 pm Hi Andy,
Cheers, Paul
Right lets now see if it validates:
auval -v aumu Stk4 Ikmm
