Audio interface with 10 outputs
Post by Octopulpo »
Hi everyone
I have a project where I need to connect my laptop to 10 different guitar amps.
My idea is to buy an audio interface with 10+ outputs (I don't really care about inputs)
For example, I found those :
https://www.thomann.de/gb/behringer_umc1820.htm (10x 6.3 mm jack line outputs (1 + 2 monitor output L/R))
https://www.thomann.de/gb/tascam_series_208i.htm (2 Balanced TRS main outputs with front level control + 6 Balanced TRS outputs + 2 Stereo headphone outputs)
https://www.thomann.de/gb/esi_u108_pre.htm (8 Balanced line outputs: 6.3 mm TRS + Stereo monitor outputs: 2x 6.3 mm jack + Headphone output: 6.3 mm jack)
My question is, with this kind of audio interface, can I send a different audio signal to each output channel at the same time? I guess(and hope) the answer is yes. But I really need to make sure about it before buying anything
Thanks in advance for your help!
Octopulpo
Posts: 1 Joined: Mon Dec 06, 2021 12:51 am
Re: Audio interface with 10 outputs
Post by Watchmaker »
The line outs from an interface won't work to drive a guitar amp. You'll need to re-amp the signal.
This should help explain things. I am not associated with Audient in any way fwiw
https://audient.com/tutorial/reamping/
Watchmaker
Posts: 1254 Joined: Wed Apr 13, 2016 12:00 am Location: Upstate NY, USA
Where does sound exist?
Post by forumuser931182 »
Covered in this SOS forum post.
https://www.soundonsound.com/forum/view ... 15&t=58133
With 10 outputs you’ll be wanting a cheap option I’d imagine
forumuser931182
Posts: 168 Joined: Fri Jul 08, 2016 4:23 am Location: Australia
And you’ll need a daw or replay software with 10 sends
forumuser931182
But you can probably just drive the guitar amps directly from the interface. You will just have to output a much lower level signal than you normally would.
forumuser931182
forumuser931182 wrote: Mon Dec 06, 2021 4:26 am But you can probably just drive the guitar amps directly from the interface. You will just have to output a much lower level signal than you normally would.
Absolutely, no extra equipment needed, and I’d go for the Behringer 1820, it’s the cheapest way out of your situation, and more than good enough.
Posts: 19916 Joined: Sat Jul 12, 2003 12:00 am
Post by blakedirksen »
I am super curious what kind of project you are working on. Mind sharing some details? Perhaps you were inspired by the recent Spitfire project (https://www.spitfireaudio.com/aperture-the-stack/).
blakedirksen
Posts: 68 Joined: Fri Aug 07, 2020 8:29 pm Location: Coralville, Iowa USA
