Project Guinjo
Project Guinjo
I started pontificating on this on a post over in the guitar forum https://www.soundonsound.com/forum/view ... hp?t=80648 , but since I have somehow accidentally started working on it, I think a proper build thread sits better here.
Here's the plan:
The first test was could I steam the neck off the old guitar-shaped-sort-of-instrument. It turns out I could:
(Lesson for self, give the steam more time to work and you won't need to be so heavy handed).
Clamping the neck to straighten things off after extraction:
Posts: 28086 Joined: Sun Jul 05, 2015 12:00 am Location: York
Re: Project Guinjo
I hope you showed the original guitar proper respect, as well as congratulating it on its selfless contribution to new life.
Oh..
and at first sight, I read that as 'Project Guano' :lol:
OK, OK, I'm leaving - no need to shove!
Posts: 19914 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Re: Project Guinjo
Folderol wrote: Tue Dec 28, 2021 6:04 pm I hope you showed the original guitar proper respect, as well as congratulating it on its selfless contribution to new life.
I'm thinking of ritually sacrificing it on a bonfire.
Re: Project Guinjo
Folderol wrote: Tue Dec 28, 2021 6:04 pm Oh..
You don't know how tempting that thought could be to someone with moderator powers. :mrgreen:
Posts: 13024 Joined: Thu Dec 05, 2002 12:00 am Location: Devon
Is it about a bicycle?
Re: Project Guinjo
Well if I balls it up it may well end up as that...
Re: Project Guinjo
The added extra two tuners are 'interesting'.
I presume they will be removed?
Two of your clamps looks suspiciously like repurposed silicon sealant dispenser guns.
Posts: 18312 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Re: Project Guinjo
Wonks wrote: Tue Dec 28, 2021 10:33 pm The added extra two tuners are 'interesting'.
The extra tuners were for two extra top strings. It was an experiment.
They will be going and I've got some left over veneer that I will use to re-face the headstock.
The clamps do look like that, and work on the same principle, but they are designed as clamps and are far more robust.
Re: Project Guinjo
I'm looking forward to seeing/hearing how this experiment turns out :clap::thumbup:
Posts: 9602 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Re: Project Guinjo
Eddy Deegan wrote: Tue Dec 28, 2021 11:24 pm I'm looking forward to seeing/hearing how this experiment turns out
Seeing, yes. Hearing, no. ;)
I presume you are keeping it nylon strung? Steel strings have at least 2-3 times the tension of nylon so you’d probably end up with quite a bowed neck if you did given the lack of truss rod.
And work back from your bridge height to determine the required neck angle. It will need more angle than it had when it was a classical-style guitar neck.
Re: Project Guinjo
Wonks wrote: Wed Dec 29, 2021 9:49 am
Actually I was going to go with Nashville tuning. That and the fact that it's a very short scale (it was a half-size guitar) should keep the tension down.
Neck angle is going to need to be worked out once I've got the drum cut down and the main centre block roughly to size and shape.
Re: Project Guano
Half-size doesn't mean half the scale length. 1/2 size scale length is typically around 530mm as opposed to around 650mm, so roughly 4/5th the scale length. Even a '1/8' classical guitar has a scale length about 2/3 of standard.
And Nashville tuning doesn't necessarily means much less tension. You're using thinner strings but under pretty much normal tension to get the required pitches.
A D'Addario acoustic 10-26 Nashville set has a total tension of just over 55kg, whilst an equivalent 10-47 acoustic set is 60kg. Whilst a set of D'Addario extra hard tension classicals strings is 41kg and a standard set 39kg.
If you tune to a normal E4 tuning for the high E, then the string tension tension will be a lot lower, but the strings will be pretty floppy and you probably won't have enough tension to keep the bridge in place or give much of a 'twang' to the sound. 3-4 semitones up would give you roughly the same string tension and string feel.
Don't forget you'll probably need to make a new a new nut, or the current one will need its slots filled with CA and baking soda and re-cut to match the much thinner strings. I doubt whether you can buy a replacement classical width nut cut for steel strings and Nashville tuning, so a new one would have to start from a blank.
Re: Project Guano
Wonks wrote: Wed Dec 29, 2021 11:49 am Half-size doesn't mean half the scale length. 1/2 size scale length is typically around 530mm as opposed to around 650mm, so roughly 4/5th the scale length. Even a '1/8' classical guitar has a scale length about 2/3 of standard.
My first confession of this project is that I didn't measure the scale length before I took it apart. :headbang: But i'll do that later.
I'll do some maths later.
A new nut is on the list, if only because the current one has two extra notches.
Re: Project Guinjo
Scale length is 20.25".
So assuming the d'addario tensions are based on a 25.5" scale, and assuming that I'm remembering correctly that the relationship between tension and length is linear, then a set of Nashville strings should give me about 44kg.
I'll give that a go I reckon.
Re: Project Guinjo
Post by ManFromGlass »
Looking forward to hearing the results!
Onwards musical explorer!
Posts: 7490 Joined: Sun Jul 24, 2011 12:00 am Location: O Canada
Re: Project Guinjo
blinddrew wrote: Wed Dec 29, 2021 1:07 pm Scale length is 20.25".
It will depend on the tuning you use. Tuned so the top open string is E4, then that seems about right. But the strings will be quite slack feeling. You’d need to tune to between G4 or G#4 to get the strings feeling normal, but then the overall tension would be back up in the 55kg area.
You could of course make a slightly thicker set of Nashville strings up to get a bit more tension in the strings.
The neck is shorter than standard and it joins at the 12th fret, both if which reduces the bending moment, and it’s wider than an a steel-strung acoustic neck so has more crosse-sectional strength. These all mitigate for the lack of a truss rod or other neck strengthening.
Re: Project Guinjo
50 years ago I strung my classical up with steel strings, 9's or 10's IIRC, and it suffered no ill effects.
Posts: 21954 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Re: Project Guinjo
I'm fairly certain I had this strung with steel strings for a while as well, but I can't recall.
We shall see how it goes.
If it does go pear-shaped then the outlay will be the cost of sandpaper, a new nut, and a set of strings.
Re: Project Guinjo
Looks to be quite a high rim on the tom. You’ll need to make a pretty tall saddle, which will need to be reasonably wide from front to back, to stop it from falling over.
Re: Project Guinjo
Sam Spoons wrote: Wed Dec 29, 2021 4:13 pm 50 years ago I strung my classical up with steel strings, 9's or 10's IIRC, and it suffered no ill effects.
Should be due to replace them about now.
Re: Project Guinjo
:bouncy: TBF I did replace the whole guitar about 46 years ago...
Re: Project Guinjo
How do you plan to anchor the strings? Simply drill holes through the steel rim?
Re: Project Guinjo
Wonks wrote: Wed Dec 29, 2021 4:23 pm Looks to be quite a high rim on the tom. You’ll need to make a pretty tall saddle, which will need to be reasonably wide from front to back, to stop it from falling over.
All of this I will need to work out as I put things together. One key question there is whether to let the fretboard overhang the drum rim, or to cut it short to offset that height. I haven't completely figured out how much that overlap will be yet.
Wonks wrote: Wed Dec 29, 2021 4:53 pm How do you plan to anchor the strings? Simply drill holes through the steel rim?
I'm planning to make up a tailpiece (see diagram one) and I'll either use the existing bridge piece (cut down) or use that as a template for something made from scratch.
That being said, I hadn't considered just drilling through the rim and I'm not writing it off as an idea, thank you. :thumbup:
Re: Project Guinjo
Wonks wrote: Wed Dec 29, 2021 9:49 am I presume you are keeping it nylon strung? Steel strings have at least 2-3 times the tension of nylon so you’d probably end up with quite a bowed neck if you did given the lack of truss rod.
I realise I got that quite wrong. It's more like 60-70% more tension with a typical set of steel acoustic strings. My now typical acoustic selection of a set of 11s is around 67kg (based on an 11-52 D'Addario phosphor bronze set), which is 61% more than the 41kg of a high tension nylon string set.
So not quite the massive extra load that I thought it was before I looked it up. It's more the top that requires the extra bracing to stop it bending and the bridge lifting on steel-stung guitars. However, a truss rod is also nice in order to counter the extra neck bow caused by the extra tension.
My 1940s 24"scale Regal parlour has no truss rod but a deeper neck to compensate. Its neck is flat with no strings on, but does take on a reasonable amount of curvature when strung with 10s. It is still playable up the neck, but it could be better.
Re: Project Guinjo
Yeah, my late 50's Hofner has no truss rod. Unfortunately even with 10-42s it developed quite a bit of curve. I keep it in open tuning now and it hasn't got any worse.
This is quite a deep neck, and it's short, and it's an experiment! :D
