Project Guinjo
Re: Project Guinjo
Just keep thinking about the bridge height. If you put a simple L-bracket on the edge of the rim, then the bridge will probably need to be at least 1cm higher than this to get a reasonable break angle. Add that to the height of the rim above the skin, and it's getting pretty tall.
Getting the string anchor point down as low as possible to the drum head removes the need for extra height just for break angle. You could do this with a more complicated bracket, but drilling holes would seem to be the simplest method and in keeping with the DIY ethos of the build.
Given the scale length of 20.25" (about 514mm), the neck's 12th fret body join and a 10" tom, it would seem the wooden centre block would need to be constructed to project the 12th fret about 3.5" away from edge of the drum shell in order to get the bridge at the fairly standard banjo position of 1/3 the way across the head from the tail end. Just sayin' loike.
Re: Project Guinjo
As I’m sure you’re aware, Drew, guinjo is Spanish for jujube, which is a Chinese red date. My partner Wendy uses them when she makes Chinese soups.
Re: Project Guinjo
Wonks wrote: ↑Wed Dec 29, 2021 5:32 pm Just keep thinking about the bridge height. If you put a simple L-bracket on the edge of the rim, then the bridge will probably need to be at least 1cm higher than this to get a reasonable break angle. Add that to the height of the rim above the skin, and it's getting pretty tall.
That's a very good point, one I hadn't considered.
Yep, that's part of the plan, possibly under-illustrated in the first diagram.
Posts: 28024 Joined: Sun Jul 05, 2015 12:00 am
Re: Project Guinjo
Cut down the drum, marked up the beginnings of the centre block, tidied up the neck a bit (including removing the end of the fretboard so that it will nestle up against the drum rim to avoid needing a stratospherically high bridge.
Work is being slowed a bit because I'm still struggling with a sprained thumb.
Re: Project Guinjo
Today has been all about the centre block, but I have made some significant progress with one of the most awkward bits of the job:
Re: Project Guinjo
That’s looking really good!
Re: Project Guinjo
Looking great Drew
Forum Aficionado - Posts: 21907 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Re: Project Guinjo
Wow - you really are enterprising and resourceful Drew!
Posts: 21633 Joined: Wed Jan 13, 2010 8:44 am
Re: Project Guinjo
I'd hold fire on the congratulations until it actually works!
Still got the neck setting to do and that's where I'm going to have to step up the precision.
Also I'm planning on over-complicating the headstock...
Re: Project Guinjo
You might consider some padding on that metal rim as it might not be too comfortable to rest an arm over, unless you’re into that sort of thing……
Not judging at. . . . . .
- ManFromGlass
Longtime Poster - Posts: 7470 Joined: Sun Jul 24, 2011 12:00 am Location: O Canada
Re: Project Guinjo
I have thought about some kind of plate here.
But I haven't thought enough to figure out how to do it.
Re: Project Guinjo
ManFromGlass wrote: ↑Tue Jan 04, 2022 3:41 am You might consider some padding on that metal rim as it might not be too comfortable to rest an arm over, unless you’re into that sort of thing……
Just view it as penance for building such a banjo-like instrument. He should probably add spikes to the rim.
Re: Project Guinjo
Heavy metal banjo? Great idea!
Perhaps with a resonator that big it will be LOUD !
We can only hope . . . . . . .
- ManFromGlass
Re: Project Guinjo
Doesn't look like much, but there's been a lot of fine tuning to get to this stage.
Neck glued:
Neck glued:
Re: Project Guinjo
Here's something that might give you a bit of inspiration (or maybe not
FWIW Duved is a superb guitarist in the Manouche style, He is achknowledged as having a very authentic sound, possibly the closest contemporary player in sound and style to Django himself. Definitely ot so sure about the banjo though
Sorry it's FB but I couldn't find the vid on YT.
https://www.facebook.com/denis.chang/vi ... 487061565/
Re: Project Guinjo
Enjoyed that Sam, good find!
Re: Project Guinjo
I gave Duved and the fiddle player a lift from Manchester Airport to March Manouche Festival where he was playing a few years ago (I volunteered at the festival a few times). Slightly odd guy, Adrian the fiddler was lovely, Duved slept the whole journey... Great player though.
Re: Project Guinjo
First coat of colour (most of which will be sanded off) and starting on the unnecessarily complicated headstock:
Colour is more patchy than I was expecting so I might have to think about trying a solid colour. But that would require buying some paint and I'm trying to do this without spending money wherever possible.
