Project Guinjo
Re: Project Guinjo
ManFromGlass wrote: Tue Jan 04, 2022 3:41 am You might consider some padding on that metal rim as it might not be too comfortable to rest an arm over, unless you’re into that sort of thing……
Not judging at. . . . . .
:smirk:
Just view it as penance for building such a banjo-like instrument. He should probably add spikes to the rim. ;)
Posts: 17048 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Re: Project Guinjo
Post by ManFromGlass »
Heavy metal banjo? Great idea!
Perhaps with a resonator that big it will be LOUD !
We can only hope . . . . . . .
Posts: 6694 Joined: Sun Jul 24, 2011 12:00 am Location: O Canada
Re: Project Guinjo
Doesn't look like much, but there's been a lot of fine tuning to get to this stage.
Neck glued:
Posts: 24699 Joined: Sun Jul 05, 2015 12:00 am Location: York
Re: Project Guinjo
Here's something that might give you a bit of inspiration (or maybe not :D )
FWIW Duved is a superb guitarist in the Manouche style, He is achknowledged as having a very authentic sound, possibly the closest contemporary player in sound and style to Django himself. Definitely ot so sure about the banjo though :smirk:
Sorry it's FB but I couldn't find the vid on YT.
https://www.facebook.com/denis.chang/vi ... 487061565/
Posts: 19763 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Re: Project Guinjo
Enjoyed that Sam, good find! :thumbup:
Re: Project Guinjo
I gave Duved and the fiddle player a lift from Manchester Airport to March Manouche Festival where he was playing a few years ago (I volunteered at the festival a few times). Slightly odd guy, Adrian the fiddler was lovely, Duved slept the whole journey... Great player though.
Re: Project Guinjo
First coat of colour (most of which will be sanded off) and starting on the unnecessarily complicated headstock:
Colour is more patchy than I was expecting so I might have to think about trying a solid colour. But that would require buying some paint and I'm trying to do this without spending money wherever possible.
Re: Project Guinjo
The words ‘glue spots’ spring to mind. You really needed to clean up better when gluing it all together.
Re: Project Guinjo
I must confess that I was expecting a bit of glue spotting but not nearly as much as this! I think it might be time to have a trawl through the paint pots and see if there's anything useable.
Re: Project Guinjo
Ok, the stain looked even worse this morning so we're definitely going solid colour. I just need to find some suitable paint.
This does actually give me the option to tidy up a bit of historic damage to the neck.
So currently it looks like this:
Overly complicated headstock coming together:
Re: Project Guinjo
Are you going to paint it all the same colour, or have the neck and body different?
Posts: 18270 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Re: Project Guinjo
Body and neck the same colour. May overcomplicate things by making the side of the fret board stand out. Headstock will be different colours.
I have a plan.
Well, an idea.
Re: Project Guinjo
Post by awjoe »
Sort of a cross between the Starship Enterprise and... a flying drum.
awjoe
Posts: 4631 Joined: Tue Mar 08, 2011 12:00 am
"The ionion was grown up with a pistol and motor."
Re: Project Guinjo
awjoe wrote: Sun Jan 23, 2022 5:38 pm Sort of a cross between the Starship Enterprise and... a flying drum.
Which may be what it becomes if it doesn't work... ;)
Re: Project Guinjo
Post by awjoe »
:bouncy:
awjoe
Re: Project Guinjo
blinddrew wrote: Sun Jan 23, 2022 5:51 pm
Make sure you achieve 'perfect pitch' :D
Re: Project Guinjo
Sam Spoons wrote: Tue Jan 25, 2022 2:56 pm
Straight into the back of the bin lorry! :D
[/Wonks]
Re: Project Guinjo
No, I’m still pushing for a natural flame finish.
Re: Project Guinjo
Thickening up the sides of the headstock to take the different tuners:
Revised headstock seen from behind (also showing that two layers of veneer wasn't enough. Unfortunately I've now run out of veneer so I'm actually going to have to buy something (washers) to complete this):
First coat of paint:
Re: Project Guinjo
Post by awjoe »
That's coming along nicely. Look, when you're done, you'll have to do a collab with BJG and his hurdy-gurdy. I'll contact the Guinness record book people.
awjoe
