The reason for asking was just to have a technical option.
I'm thinking on starting to offer as a session bass player and I want to be sure I'm can delivering a close to studio audio quality wav
Thanks for you feedback
Assuming your bass signal is peaking up to somewhere between -10dBFS and -20dBFS I don't see a problem. If the bass is only peaking -80dBFS there is a problem...
If I was looking for a session bass and I had to choose between something that sounded like Billy Sheehan on fire but with a bit of recording noise, or Joe from the band down the pub tracked at Air Studios on the quietest signal chain known to man, I know what I'd be choosing.
Some numbers: I plugged my rubbish Hondo bass into my MOTU M 4 and set gain for -20dBFS peaking to -10ish. I then stopped playing and oriented the bass for least noise pickup. Reading was a 'blippy' -66dBFS.
Chopped off the noodling part and just exported the noise to Right Mark Anny and the mid band level was -126dB but with a whopping 50Hz peak at -90dB, there was another lesser peak at 150Hz.
Certainly a better quality bass should be less noisy but I doubt even the best rig will get below -75dBFS and keep away from big transformers!
