RichardT wrote: ↑Sun Jan 16, 2022 1:12 pm
Don’t do it Tony! There’s absolutely no need to compress your inputs when recording as long as you use 24 bits. Leave plenty of headroom and you’ll be ok.
Compressing the input just takes away options from you when it comes to sorting out the dynamics at mixing time.
If you are trying to figure out "Dynamics" at "Mix time"
You've got far bigger problems to worry about then where you put your compressor.
If you get to "Mix time" and find that you need "Options"
Your problem is likely terminal.
It shows you had no vision for what it was you were setting out to do in the first place.
To the OP, your problem is not that you don't know where to put your compressor, or the type of compressor you should be using....
Your problem is that you don't know how or why to use it in the first place.
I suggest you spend some time digging into the subject of compression, learn WHY you would use a compressor in the first place. And learn it with your ears, I'm sure you know what a compressor does.....but can you HEAR it adding something to your music that you intended it to?
Rhetorical question.
