Unknown rock drum loops from 90s-2001
Post by DimaOldSchool »
Is anyone here who knows where these drum loops came from?
https://www.youtube.com/watch?v=2dMTeeaFlik
All the tracks with drum loops were recorded in 2001.. I believe it was kind of acid loops CD. I checked Drum Tools, DPD, Burning Grooves, Joey Kramer Drumloops and couple others sample CDs but nothing...
DimaOldSchool
Posts: 2 Joined: Thu Jan 20, 2022 6:28 pm
Re: Unknown rock drum loops from 90s-2001
Welcome.
These are not drum loops... :?
Posts: 21008 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
The Elf wrote: Thu Jan 20, 2022 7:35 pm Welcome.
What makes you think so? I have couple of other tracks with the same drum loops but the difference is that drum tracks are stretched out and pitched little bit.
DimaOldSchool
They are just programmed (or played) drums - not looped. What makes you think they are loops?
It would be a simple task to program these example sections up as MIDI parts, driving a sampler, and you'd be done. The trick is getting the right drum samples. There are a lot of free drum sample libraries (and sample players) on the net, so grab some samples you like and program the rhythm as you hear it in those examples - job done. And then if you want the pattern to loop just repeat the MIDI pattern.
You could even just drop the samples into audio tracks, if using a sample player is not ideal.
Post by BJG145 »
DimaOldSchool wrote: Thu Jan 20, 2022 8:02 pm
The Elf wrote: Thu Jan 20, 2022 7:35 pm These are not drum loops
...the thing about drum loops is that, they loop, they repeat. These fragments don't contain identical repeated sections...
Posts: 7724 Joined: Sat Aug 06, 2005 12:00 am Location: UK
