Is anyone here who knows where these drum loops came from?
https://www.youtube.com/watch?v=2dMTeeaFlik
All the tracks with drum loops were recorded in 2001.. I believe it was kind of acid loops CD. I checked Drum Tools, DPD, Burning Grooves, Joey Kramer Drumloops and couple others sample CDs but nothing...
Unknown rock drum loops from 90s-2001
- DimaOldSchool
- Posts: 2 Joined: Thu Jan 20, 2022 6:28 pm
- DimaOldSchool
Re: Unknown rock drum loops from 90s-2001
They are just programmed (or played) drums - not looped. What makes you think they are loops?
It would be a simple task to program these example sections up as MIDI parts, driving a sampler, and you'd be done. The trick is getting the right drum samples. There are a lot of free drum sample libraries (and sample players) on the net, so grab some samples you like and program the rhythm as you hear it in those examples - job done. And then if you want the pattern to loop just repeat the MIDI pattern.
You could even just drop the samples into audio tracks, if using a sample player is not ideal.
...the thing about drum loops is that, they loop, they repeat. These fragments don't contain identical repeated sections...
