Is Monitor Left on my left as I look at the monitors, or left as the performers would see the monitors facing the audience. Is Stage Left left as the audience sees it, or left as the performers (don't) see it.
I've often wondered but never been concerned, until now. I'm re-connecting everything including various monitors in my new room and I really want to get it right finally. I'm pretending to myself that I've become more professional.
Monitor L, Monitor R, Stage Left, Stage Right
- Howdy Doody Time
Frequent Poster - Posts: 806 Joined: Sun Jan 18, 2009 12:00 am Location: Huai Yai, Chon Buri, Siam
The only excuse we have for making music in the first place is to make it differently..vis-a-vis our own difference (Glenn Gould)
Re: Monitor L, Monitor R, Stage Left, Stage Right
Stage Left and Right are as seen FROM the stage, ie the performer’s viewpoint. I believe this convention originates in the theatre, but is applied in music venues too.
I’ve not considered Monitor Left and Right before, but now that I do, I would imagine them to be from the listener’s perspective, ie the opposite of the stage convention.
- djangodeadman
Regular - Posts: 354 Joined: Tue Feb 18, 2003 12:00 am Location: Brighton
As said above, stage left/right is as perceived by someone standing on the stage looking out to the audience.
If the monitors are on the stage for the benefit of the artists then I'd use the same frame of reference for them.
The audience perspective is typically referred to as camera left/right, and that is obviously the reverse or mirror image of stage left/right.
Posts: 39087 Joined: Fri Jul 25, 2003 12:00 am
Hugh Robjohns wrote: ↑Sun Jan 23, 2022 9:22 am The audience perspective is typically referred to as camera left/right, and that is obviously the reverse or mirror image of stage left/right.
Or, in the theatre, "House Left/Right"
WRT stage monitors, I can't remember the last time I worked with stereo foldback but for several mono monitors I number them from my perspective (I also have my tom mic channels arranged in the same way) and from front to back.
Jedi Poster - Posts: 19758 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Yeah - but what if an artiste wearing stereo IEMs turns his / her back to the audience ?
- Saxum esse et non provolvere
Poster - Posts: 74 Joined: Wed Feb 22, 2006 12:00 am Location: Wherever my van is, UK
"Stage right is the actor’s right as the actor stands on the stage facing the audience.
Stage left is the actor’s left as the actor stands on the stage facing the audience.
If the actor is facing up stage (toward the back wall), stage right and stage left are determined as if the actor were standing on the stage facing the audience. So the left side of the stage is always the left side. It doesn’t change when the actor faces different directions. The right side of the stage is always the right side. It also doesn’t change when the actor faces different directions."
Quite right! Sorry -- my TV background shining through!
Not suggesting you were wrong Hugh (heaven forfend ) just that there were other conventions...
For some reason I had assumed the question referred to studio monitors. In the case of stage monitors I would refer to the monitors from the performer’s viewpoint.
- djangodeadman
Saxum esse et non provolvere wrote: ↑Sun Jan 23, 2022 11:40 am Yeah - but what if an artiste wearing stereo IEMs turns his / her back to the audience ?
They deal with it being the wrong way around
- Dave Rowles
Posts: 1456 Joined: Thu Feb 28, 2008 12:00 am
http://www.manninmusic.com Teacher - Isle of Man
http://www.manninmusic.shop Music Shop - Isle of Man
https://www.facebook.com/mannin.sound - PA Hire/Sound Engineer - Isle of Man
Hugh Robjohns wrote: ↑Sun Jan 23, 2022 12:23 pm
Or stereo/listener left/right in radio world.
And as for IEMs, they're just left and right since the wearer's persepctive of them never changes. Not without some discomfort anyway.
It can be 'fun' remembering to whom one is talking and which perspective they use when dealing with stage managers talking layouts at the same time as working on radios with a team of riggers hanging mics in a roof space where they can't see the stage properly and arm waving/pointing/hand signals aren't visible!
- forumuser840717
Regular - Posts: 448 Joined: Thu Jun 16, 2016 5:20 pm
