A Newbie Asks About Omni Microphones
Re: A Newbie Asks About Omni Microphones
This is where having microphones with good off-axis response helps I think.
Forum Aficionado -
Posts: 24714 Joined: Sun Jul 05, 2015 12:00 am
Hugh Robjohns wrote: ↑Fri Feb 25, 2022 11:44 amAled Hughes wrote: ↑Fri Feb 25, 2022 11:41 am So the 90 degree placement ‘trick’ only works for close sources?
Correct.
I record a grand piano with two DPA 2006C omni mics (which are diffuse field) in the upright position very close to the strings with open lid, and this works very well. So I can recommend this technique - which I originally heard of from Hugh - some time ago.
MBHO / Haun in Germany make good modular small-diaphragm mics that are more affordable than Schoeps etc, and have a diffuse-field omni capsule in the range.
- Sam Inglis
Moderator - Posts: 3042 Joined: Fri Dec 15, 2000 12:00 am
Thanks Sam!
- Mike Stranks
Jedi Poster - Posts: 10474 Joined: Fri Jan 03, 2003 12:00 am
Aha!
I've just found these for the OM1:
https://www.shapeways.com/product/5KY2M ... -audio-om1
So I think I'll stick with the OM1s - far too much 'Seller's Remorse' in my life! - and get a couple of these...
... Yes; I have read Hugh's explanation of the difference between such devices and a true diffuse-field mic ...
[BTW... someone queried my 'newbie' status on this... most of us are newbies in some aspects of the wonderful world of sound and I'm happy to confess that I've previously not bothered over-much about near-field and diffuse-field. In other news, I'm finally starting to experiment with MIDI!]
- Mike Stranks
Mike Stranks wrote: ↑Mon Feb 28, 2022 10:02 amIn other news, I'm finally starting to experiment with MIDI!
Forum Aficionado -
Mike Stranks wrote: ↑Mon Feb 28, 2022 10:02 amIn other news, I'm finally starting to experiment with MIDI!][/size]
We will make you a MIDI guru yet, Mike!
