Pitch shifting without delay.
Is there such a thing?
I’m fed up with this delay, between when you play and when you hear the shifted note, it’s only acceptable if you mix the processed signal really low.
It doesn’t seem to matter what unit you use, everything I’ve owned has this really annoying delay, I’ve just accepted it as part of the way it works.
Eventides, no better, Lexicons, right through pedals etc, it’s always there.
Has anyone tried anything that at least gets this down to negligible levels?
Posts: 19884 Joined: Sat Jul 12, 2003 12:00 am
Re: Pitch shifting without delay.
Arpangel wrote: Mon May 16, 2022 8:44 am Is there such a thing?
No. Yae cannae change the laws of physics!
Posts: 42194 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by RichardT »
The only way to do it is to pitch shift a midi signal not the audio. That can be done almost instantaneously.
RichardT
Posts: 4983 Joined: Fri Aug 13, 2004 12:00 am Location: UK
RichardT wrote: Mon May 16, 2022 8:57 am The only way to do it is to pitch shift a midi signal not the audio. That can be done almost instantaneously.
If you do it that way, it just sounds like more notes are being played! :D
And you can only do it with Midi instruments, not voices or anything acoustic.
The tonal artefacts of pitch shifting are great, that’s what I like, it’s just the delay that bugs me.
Actually, with voices it’s not so noticeable, it sort of blurs a bit, but it’s with synths that it’s really obvious, it’s OK if you want that as an effect, but not all the time.
Post by forumuser931182 »
Apparently when Pat Metheny used one of the very early guitar synths it had a really long delay when it tracked the guitar note so he had to play everything slightly ahead of the rest of the band. If you do this the pitch shifted output will be in time and then your unshifted signal can go through a simple time delay to perfectly sync. Simple.
Another good point is you’ll finish the gig before rest of the band so can get to the bar first.
forumuser931182
Posts: 168 Joined: Fri Jul 08, 2016 4:23 am Location: Australia
forumuser931182 wrote: Mon May 16, 2022 9:18 am Apparently when Pat Metheny used one of the very early guitar synths it had a really long delay when it tracked the guitar note so he had to play everything slightly ahead of the rest of the band. If you do this the pitch shifted output will be in time and then your unshifted signal can go through a simple time delay to perfectly sync. Simple.
:D:D:D
Oh man, please, you cannot imagine me doing that, even if my musicianship was good enough!
I'm obviously no Pat Metheny* but using my Variax live in some of the more complex voicings, especially with a bit of internal re-tuning, you do have to compensate for the latency and it's actually quite easy to get into the habit of playing ahead - as long as you have decent monitoring.
* contender for understatement of the year. ;)
Posts: 28072 Joined: Sun Jul 05, 2015 12:00 am Location: York
Synth string patches have a lot of apparent latency due to the slow attack
but I didnt realise how much my playing was automatically compensating for this untill I saw it on the computer.
Posts: 4552 Joined: Sun Aug 12, 2018 2:40 pm Location: British Isles
blinddrew wrote: Mon May 16, 2022 11:14 am I'm obviously no Pat Metheny* but using my Variax live in some of the more complex voicings, especially with a bit of internal re-tuning, you do have to compensate for the latency and it's actually quite easy to get into the habit of playing ahead - as long as you have decent monitoring.
I don’t understand, how can you compensate? no matter how fast you play, you’ll still be out of time.?
Presumably it is the same as with pipe organs? If the original note sound without latency you would need to set the pitch shifting box to 100% wet and split the original signal off to a delay so that it was delayed by the same amount as the pitch shifted note. Then you just have to play ahead of the beat by just enough for the notes to sound at the appropriate time.
Posts: 21943 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Sam Spoons wrote: Mon May 16, 2022 3:26 pm Presumably it is the same as with pipe organs? If the original note sound without latency you would need to set the pitch shifting box to 100% wet and split the original signal off to a delay so that it was delayed by the same amount as the pitch shifted note. Then you just have to play ahead of the beat by just enough for the notes to sound at the appropriate time.
Thanks Sam, all clear!
The thing about the organ, is that all you hear is the original sound, but yes, if it’s a very big cathedral, it can be a big delay.
N i g e l wrote: Mon May 16, 2022 12:27 pm Synth string patches have a lot of apparent latency due to the slow attack
So true!
I've also been surprised at how much earlier the note-on's of some of my string parts are than the rest of the instruments.
It's actually so much easier to play in a slow attack string part rather than attempt to draw it in, because you do compensate for the feel automatically.
Posts: 21662 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Post by Honch »
Interesting subject. I thought, at last, someone agrees with me. The problem I have mostly is pitch shifters with deliberate delay units after. I e another echo effect after. Some software but most pedals have this strange, that the timing gets off.
I'll explain:
I have a pitch shift for - say - guitar one octave up. When I play it, it has those inevitable lag time to track which pitch it is. On software on computers it's very long, as it is added to soundcard latency as well as rountrip latency.
Now, after that, you want a regular echo delay, at say 400 ms. In order to play in tempo, say the first pitch shift latency (i e time of the pitch shift to track spot on and let it out) is 5 ms, the FIRST repeat is 400 ms after, but the second repeat of the echo is at 405 ms, third at 410 ms and each subsequent repeat added 5ms, because it has to track the new pitch shift each time. Impossible to keep BPM tempo.
Now, the only pedal that I have encountered that does this right, is the Eventide Rose pedal. Although mainly as a delay, it's the only unit (physical) I know of, that uses feedback for it's delay OUTSIDE of the digital loop. It goes out from the D/A and back in again IN FRONT of the A/D again. As such you can self modulate/oscillate without digital artifacts, and if pitch shifting is used, it has that 400 ms delay after each repeat anyway. I do not own it, I think it's too expensive obuy for such a niched sound. I an awaitng a sale someday, or closeout deals.
Don't forget that the higher the pitch conversion ( i e one octave higher) the longer it takes, and on some software, or pedals, or multifx units one can use settings like "fast" or "slow but accurate" that the pitch doesn't sound out of tune. If you use low pitch like a 10 cent chorus pitch shift, use fast, because there it doesn't matter.
Still, the best and fastest pitch shifter I tried is the ancient blue MXR racks of the 80s. Limited in options but very fast and accurate tracking, better than Eventide 910 at the time. Still today. My friend has one and we measured once at +12 semitones (one octave up). It was 6 ms. For downshifting, one octave low I use a regular octaver instead. Much better.
Honch
Posts: 92 Joined: Mon Dec 25, 2017 11:56 am
Arpangel wrote: Mon May 16, 2022 3:19 pm
You don't play fast, you play ahead.
But we’ve got satellites going around the earth, missiles that can destroy whole cities anywhere in the world, mobile phones and computers, why can’t I get a pitch-shifter with zero latency?
Post by Music Wolf »
Arpangel wrote: Tue May 17, 2022 7:05 am But we’ve got satellites going around the earth, missiles that can destroy whole cities anywhere in the world, mobile phones and computers, why can’t I get a pitch-shifter with zero latency?
Speaking as a Physicist I can promise you that, just as soon as we've cracked time travel, it's the next job on the list.
You can't shift a wave until the wave has passed.
Music Wolf
Posts: 2865 Joined: Fri Feb 17, 2006 12:00 am Location: Exiled to St Helens
Music Wolf wrote: Tue May 17, 2022 8:38 am
I don’t suppose there’s any chance of moving my problem up the list a bit, after all, who needs time travel, when you’ve got us.
Arpangel wrote: Tue May 17, 2022 8:51 am
Unfortunately the time travel bit is an enabler for the zero latency pitch shifting but don't worry, if we can solve it you'll have had it yesterday. :bouncy:
Music Wolf
Music Wolf wrote: Tue May 17, 2022 8:55 am
Would faster chips help?
the thing thats making the original wave - couldn't you just buy another one, tune it differently and play them in sync ?
N i g e l wrote: Tue May 17, 2022 9:37 am the thing thats making the original wave - couldn't you just buy another one, tune it differently and play them in sync ?
Trouble is, it doesn’t sound the same as pitch shifting, that nice dirty thick sound, that’s slightly unstable, but it’s no problem, I can live with it, I can rise above it, I’m a professional.
https://www.youtube.com/watch?v=BHGJEdjCoeU
:D:D:D
Arpangel wrote: Tue May 17, 2022 8:59 am Would faster chips help?
No, forcing the pace inevitably loses the flavour ;)
Post by fruitcake »
Perhaps slower ears
fruitcake
Posts: 322 Joined: Sun Apr 22, 2018 4:32 am Location: Beautiful Downtown Burbank
Here are some Unfinished Sounds.
Arpangel wrote: Tue May 17, 2022 10:40 am Trouble is, it doesn’t sound the same as pitch shifting,
:D:D:D
You Sir, are very naughty young man !
