AU and VST on Mac, and changing to Logic.
I’ve been using VST's on my Mac for ages, without realising that I should be using AU's.
I have a had a few issues, but they are rare, also, all of the Cuckos Reaper plugs are VST's, and I’m using Reaper.
I am vaguely thinking of changing to Logic, I’ve been using Garage Band a lot, and I like that type of workflow, I’m guessing Logic is like that only more complex, with better plug-in's.
Posts: 16713 Joined: Sat Jul 12, 2003 12:00 am
Re: AU and VST on Mac, and changing to Logic.
Post by Kwackman »
Arpangel wrote: Mon May 16, 2022 3:40 pm I’ve been using VST's on my Mac for ages, without realising that I should be using AU's.
Say's who?
IFAIK the DAW determines this, not the platform.
I think Logic only uses AU, so that's why you might need to change.
I've run Cubase on a Mac for decades, and always VST as that what Cubase works with. Never had an issue.
Most Mac plug-ins are available in both AU & VST versions.
Edit to add...
It might be possible to run AU in a VST DAW (and vice versa) using a convertor, but the cowardly part of me wouldn't want to do it, as it's something else to screw everything up!
Kwackman
Posts: 3226 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
Post by dbfs »
I think using VSTs is the best option when on a Mac using Reaper as it may well give you more flexibility moving/sharing projects to the PC platform.
In fact in Reaper prefs you can tell it to hide AUs, which is automatic set for All waves plugins at their request. I also hide all other AUs to keep things smooth between my mac and windows computers.
dbfs
Posts: 314 Joined: Fri May 07, 2004 12:00 am
dbfs
Thanks, I’ve been thinking about this because I’ve had issues with a couple of plug-ins as VST's, I changed them to AU, and the problems disappeared.
But I’ve had no issues with Reapers stock VST plug-ins.
