Buzz/Hum Hm?
Buzz/Hum Hm?
I wonder if you could suggest ways for me to deal with this small problem.
(I call it a small problem because it's smaller than it used to be.)
Here's what I'm trying to do - I want to run both my KRKvxt8's and my Avantone mixcube through my new Mackie Big Knob Passive monitor controller and have minimal buzz/hum.
There's no problem with the KRK's through the Big Knob A Channel - I'm using TRS 1/4" jacks and it's quiet.
I then tried unbalanced cables with the Avantone, but the noise was terrible. So I hooked up the Avantone this way:
* XLR into the Avantone, which splits into two XLR female jacks.
* I attached two XLR male to 1/4" balanced jacks to the females, and the 1/4" balanced jacks into the Mackie Big Knob controller B Channel inputs.
I now get buzz/hum from the Avantone (but much, much less than when I used an unbalanced connector), but here's the kicker - I'm now getting a bit of hum/buzz from the KRK's as well, hum/buzz that wasn't there before. If I turn the Avantone off, the hum through the KRK's stops. Bad Avantone. Bad.
Any ideas about how to get my monitors as quiet as a quiet thing?
"Don't try to teach a pig to sing - it doesn't work, and it irritates the pig.'
Re: Buzz/Hum Hm?
To be brutally honest Awjoe, I suggest you ditch the Mackie PBK in favour of a better controller (even a small mixer is better IMHO!)
The Passive BK suffers from two (three if you count that they have done the same Bad Thing twice!)
First off, the 'cold' side of the balanced (not really) input TRS has the low resistance of 1k to ground. This is low enough to cause distortion with some sources. Even if there is no distortion the input resistances are about an order apart and so all 'balance' is lost.
Secondly the 'hot' 'cold' output lines are again at very different resistances and therefore you are NOT getting anything like a balanced output.
My PBK is now gathering dust in a spare bedroom (free to any passing oik!) and I use a Behringer X 1202 to 'gather' signals from my TV (via an optical D/A) a CD players, feeds to and from my M4 and ultimately a DI feed from an HT-20. Sounds very good to me on my Tannoy 5As and noise levels are well below audibility.
Re: Buzz/Hum Hm?
You probably need to isolate the Avantone ground from that of the Passive controller to break the ground-loop which is causing the hums. So I'd suggest installing an ART DTI or Cleanbox2 between the controller and aventones.
Posts: 42142 Joined: Fri Jul 25, 2003 12:00 am
Re: Buzz/Hum Hm?
Hugh Robjohns wrote: ↑Sat May 21, 2022 11:31 am You probably need to isolate the Avantone ground from that of the Passive controller to break the ground-loop which is causing the hums. So I'd suggest installing an ART DTI or Cleanbox2 between the controller and aventones.
I am sure you are right Hugh in that Awjoe's problem is a ground loop I just wanted to make him aware of the problems with the BK which might make diagnosis more difficult? I.e. hum in a 'balanced' system that is not by any means balanced is not a good start!
My first fix was a pair of SparkFun U/B to balanced out modules to feed the Tannoys. I only needed the hot signal from the BK. Then I reasoned that the feed from the hi fi amp to the BK might not be so good so I put the Sparks in that line and now get a balanced speaker feed from the mixer.
One day I shall treat myself to a better, active controller.
Re: Buzz/Hum Hm?
Dave: I just got the Big Knob, so I don't want to ditch it right away lol. I like everything about it, other than the small hum issue when I add the Avantone to the system.
Hugh: I'll try the ART DTI - I've got an ART ZDirect for bass recording purposes, and I've liked it.
Thanks very much, you two. My tech chops don't extend beyond 'use balanced cables for this'.
Re: Buzz/Hum Hm?
In the end, satisfaction was had, not by the insertion of an isolator, but simply by plugging the second monitor (the mixcube) into a socket on a different circuit. Duh.
Re: Buzz/Hum Hm?
I'm glad your hum has gone away, but it will be back another day
Essentially by plugging in your monitor to a different mains socket you have changed the size of the ground loop, which (as luck would have it) has reduced the amount of hum. However, that ground loop is still there, and when you plug some other gear item in that hum could return with a vengeance. Just enjoy the relative silence for now.
Posts: 21627 Joined: Wed Jan 13, 2010 8:44 am
Re: Buzz/Hum Hm?
Ah yes. Rule 1: Always make sure all the gear is powered from the same wall socket, ideally with a star-distribution of plugboards. This minimises the size of the 'loop' and ensures everything is tied back to the same single safety earth reference.
Using different wall sockets almost guaranties a ground-loop with different safety earth reference voltages to different bits of gear, and hence audible ground-loop hums.
But as Martin says, the physical ground-loop is still present, it's just that both ends are at the same ground potential, so there is very little noise current flowing and hence inaudible hum. So adding more gear, and especially if that is powered from a different wall socket, is likely to alter the ground current and may thus bring back audible hum.
The isolation transformer suggested earlier inherently breaks the loop and provides a permanent fix.
Re: Buzz/Hum Hm?
FWIW, the problem cropped up when all devices were plugged into the same electrical source, the same plugboard. The problem ended (Martin says the fix is likely temporary) when I plugged one of the devices (the mixcube) into a different socket entirely. This doesn't follow the pattern you're describing, so it looks like it's a case of 'variables produce variability', and I expect the problem will re-appear at some point, and from what you've said and from what I've been able to understand from reading about it, the isolator looks to be the simplest solution.
I'll get this working though, because the advantages of having the contoller are numerous and powerful.
Re: Buzz/Hum Hm?
I have a similar situation with a valve mic. If it's plugged into the same socket as everything else I get hiss and hum.
Stick it in a socket on the other side of the room and it behaves itself perfectly.
Ground loops hey!
Ground loops hey!
Posts: 28013 Joined: Sun Jul 05, 2015 12:00 am
Re: Buzz/Hum Hm?
Oh... sorry. Confirmation bias: I read what I expected to be the case and not the actual case!
Ground-loops are little buggers!
There are a number of possible explanations for your apparent good fortune, but the scariest one is that the alternative wall socket is lacking a safety earth completely, or it has a high enough ground impedance to subdue the loop current to a negligible level.
Alternatively, it's possible that you have multiple loops and the current via one route ends up being in the opposite polarity to another, effectively cancelling each other out.
Re: Buzz/Hum Hm?
Is the only difference the mains socket location, or do you locate the PSU in different places when using the different sockets?
Re: Buzz/Hum Hm?
Nope, that's a good shout, the PSU is also in a completely different place.
Re: Buzz/Hum Hm?
Hmmm... there could be an audio transformer within the PSU which is picking up the field radiating from a nearby mains transformer in the first location but not the second... or something along those lines.
Re: Buzz/Hum Hm?
Absolutely, it was previously sitting on top of my minidisc player (don't laugh!) which doesn't have a hard off-switch just a standby.
Re: Buzz/Hum Hm?
Whatever the reality behind the symptoms is, it got me reading and learning (SOS and Wikipedia articles), and you've all been very helpful. And if it goes sideways again, I've got things to try out. Thanks, all.
Re: Buzz/Hum Hm?
Ah, that explains the hiss too.
Digital gear often radiates all manner of nasty RF stuff in the local area which can easily get demodulated into a hiss-like interference.
Re: Buzz/Hum Hm?
Which is good to know, but I am now having some regrets about my last microphone purchase...
Re: Buzz/Hum Hm?
Hugh Robjohns wrote: ↑Mon May 23, 2022 9:05 pm
What about a wireless modem/router within two meters of the gear that is ostensibly the scene of the ground loop? Major culprit?
Re: Buzz/Hum Hm?
Picking up on two previous posts...
Routers: I'm having some issues in one of 'my' church installs. They recently installed a digital recorder which is picking up all manner of chirps and whistles. There is a router and 'Ethernet via mains' gear about a metre away. Investigations continue...
CD and other digital players: I discovered many years ago that these do not make good bedfellows with radio-mic receivers...!
- Mike Stranks
Jedi Poster - Posts: 10585 Joined: Fri Jan 03, 2003 12:00 am
Re: Buzz/Hum Hm?
Mike Stranks wrote: ↑Tue May 24, 2022 8:52 amThey recently installed a digital recorder which is picking up all manner of chirps and whistles. There is a router and 'Ethernet via mains' gear about a metre away. Investigations continue...
The Ethernet via the mains would be the first thing to check out, I think. And then I'd look at the integrity of the unit's screening and those of cable connections. A powerful router within a metre could easily cause interference problems.
And yes, anything digital does not make good bedfellows with analogue radio mic receivers.
Re: Buzz/Hum Hm?
Re: Buzz/Hum Hm?
Even LED lighting could be causing problems. I was telling our lad about short wave radio this morning and showing him on a Sony portable. We couldn't pick up anything until I switched off the LED lights that were near the aerial. They were supposed to be 12V DC but there was obviously noise from the switch mode power supply getting onto the cables.
Posts: 15849 Joined: Mon Sep 10, 2001 12:00 am
