Is the only difference the mains socket location, or do you locate the PSU in different places when using the different sockets?
Buzz/Hum Hm?
Re: Buzz/Hum Hm?
Posts: 39042 Joined: Fri Jul 25, 2003 12:00 am
Re: Buzz/Hum Hm?
Nope, that's a good shout, the PSU is also in a completely different place.
Forum Aficionado -
Posts: 24664 Joined: Sun Jul 05, 2015 12:00 am
Re: Buzz/Hum Hm?
Hmmm... there could be an audio transformer within the PSU which is picking up the field radiating from a nearby mains transformer in the first location but not the second... or something along those lines.
Re: Buzz/Hum Hm?
Absolutely, it was previously sitting on top of my minidisc player (don't laugh!) which doesn't have a hard off-switch just a standby.
Forum Aficionado -
Re: Buzz/Hum Hm?
Whatever the reality behind the symptoms is, it got me reading and learning (SOS and Wikipedia articles), and you've all been very helpful. And if it goes sideways again, I've got things to try out. Thanks, all.
I long for the days when I knew what nostalgia was.
Re: Buzz/Hum Hm?
Ah, that explains the hiss too.
Digital gear often radiates all manner of nasty RF stuff in the local area which can easily get demodulated into a hiss-like interference.
Re: Buzz/Hum Hm?
Which is good to know, but I am now having some regrets about my last microphone purchase...
Forum Aficionado -
Re: Buzz/Hum Hm?
Hugh Robjohns wrote: ↑Mon May 23, 2022 9:05 pm
What about a wireless modem/router within two meters of the gear that is ostensibly the scene of the ground loop? Major culprit?
Re: Buzz/Hum Hm?
Picking up on two previous posts...
Routers: I'm having some issues in one of 'my' church installs. They recently installed a digital recorder which is picking up all manner of chirps and whistles. There is a router and 'Ethernet via mains' gear about a metre away. Investigations continue...
CD and other digital players: I discovered many years ago that these do not make good bedfellows with radio-mic receivers...!
- Mike Stranks
Jedi Poster - Posts: 10467 Joined: Fri Jan 03, 2003 12:00 am
Re: Buzz/Hum Hm?
Mike Stranks wrote: ↑Tue May 24, 2022 8:52 amThey recently installed a digital recorder which is picking up all manner of chirps and whistles. There is a router and 'Ethernet via mains' gear about a metre away. Investigations continue...
The Ethernet via the mains would be the first thing to check out, I think. And then I'd look at the integrity of the unit's screening and those of cable connections. A powerful router within a metre could easily cause interference problems.
And yes, anything digital does not make good bedfellows with analogue radio mic receivers.
Re: Buzz/Hum Hm?
Re: Buzz/Hum Hm?
Even LED lighting could be causing problems. I was telling our lad about short wave radio this morning and showing him on a Sony portable. We couldn't pick up anything until I switched off the LED lights that were near the aerial. They were supposed to be 12V DC but there was obviously noise from the switch mode power supply getting onto the cables.
Posts: 14380 Joined: Mon Sep 10, 2001 12:00 am
Re: Buzz/Hum Hm?
Reviving an old thread here...been having the same issue as the OP and the Avantone Customer Service guys confirmed the Mixcube just doesn't play well with the Big Knob Passive and suggested getting a powered monitor controller.
Now, my 'temporary' solution has been to use a travel adapter that has a plastic ground pin (I am in the UK and most travel adapters come with a plastic ground pin).
Wall plug > Surge protected power strip > travel adapter > Avantone power supply
This has eliminated the problem completely, no buzz from the Mixcube, no buzz from my main monitors...but not the safest options as far as I understand.
Is the only possible 'definitive' solution to use an ART DTI or similar then??
