Hello !
Has anyone had the problem. It started by the disc rotating irregularly with a slight scratching noise, the green light blinking irregularly. Now the motor is clearly engaged but the disc doesn’t move. Can someone tell me what i can do and what the problem could be ?
Thank you very much !!!
Alexander ( Paris)
EMT 948 turntable : the motor working but does not turn. Th
Re: EMT 948 turntable : the motor working but does not turn. Th
Contact EMT. It's broken.
Posts: 39101 Joined: Fri Jul 25, 2003 12:00 am
